![]() ![]() Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2016
Do I need an alignment?
Do I need an alignment after installation of Eibach 1.4 in (Front) 1.4 in (Rear)lowering kit?
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85 |
![]() Drives: 2018 1SS 1LE Join Date: Apr 2018
Yes
2018 1SS 1LE (sold) |
Balls On a Heifer! I was not prepared for the additional cost after installation. Thanks for the info.
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Chances are your car needed one before the install too. It appears fairly rare that the Lansing factory gets the alignments spot-on.
For sure you need an alignment now. To change the springs you loosened (in the rear) or removed (in the front) the camber adjusters, so for sure the camber will be wonky. Also with the lowering, your rear trailing arm bushings are now cocked and need to be loosened and re-torqued at the new ride height. Finally, the front suspension has some bump steer, so your front toe will be off by an appreciable amount. TL;DR, Alignment is required, not optional.
#5 | |
