![]() Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
NEW ACT T1R-G09 CLUTCH 1140 TORQUE OEM PEDAL FEEL
I have a brand new ACT t1R-G09 clutch for sale, I bought it to install on the car but we are going with a th400 now so no need. Never installed, brand new. Discount is because it is out of box, however the spaced and hardware are still in packaging. Asking $900 buyer pays shipping.
————————————————————————————————————————— T1R-G09 twin disc kit offers twice the number of disc surfaces for better wear, heat capacity and long life compared to single disc kits. These kits use a proprietary Positive Lift Floater System design, which results in quiet operation with no floater rattle and no posts to wear. ACT twin disc kits endure an exclusive four-stage, heat treating process performed on all diaphragms. The ACT twin disc features the ability to adjust for disc wear and provides equal disengagement for discs. ACT's 6-pad rigid race discs are made with high quality, ceramic friction materials. The chrome-moly hub is heat-treated for strength and durability. The lightweight, rigid design allows for quicker shifts and trouble-free service. All ACT twin disc kits include a CNC-machined and dynamically balanced flywheel to ensure trouble-free installation and operation. ACT twin disc kits include a pressure plate, two discs, a floater, flywheel and alignment tool. Some kits may include a pilot bearing and release bearing. Feel - Light pedal effort, quicker shifts, aggressive engagement, mild to moderate gear rattle Life - Doubles the number of disc surfaces for better wear, heat capacity and longer life, extended by ACT's exclusive diaphragm design Quality - Carefully engineered, precisely assembled, accurately balanced, uses select ceramic friction materials for high heat tolerance and maximum performance Recommended Use - Recommended for race use only ACT Difference - 100% clamp load tested and dynamically computer balanced for smooth high RPM reliability Torque Capacity (ft/lbs.):1140 Torque Capacity Over OE:73% SFI:1.2 Flywheel Tooth Count:168 Disc Type:Race Disc Spline Count:26 Spline Size (in.):1-1/8 Disc Diameter (in.):10.5 Disc Diameter (mm.):267 Product Weight (lbs.):43.2 Warranty (Product Warranty):One (1) Year from Retail Purchase |
Are you selling the TR6060?
Rotofab, PRAY IM/TB, SE 1 7/8 longtubes full system, SM FLEX FUEL KIT, Custom Exhaust, Mishimoto Catch can, FBO, street tuned.
![]() Drives: 2010 SS/RS & 2017 SS/RS Join Date: Jan 2009
Sold?.?.?..?.?.!
![]() Drives: 2017 2SS, M6, Silver Join Date: Jun 2018
Still available?
17 2SS, Pray Performance Forged/Stroked 416, 2.9 Whipple (Pray ported), Stage 2.5 Pray ported heads, RotoFab Big Gulp, Katech 103mm TB, Pray Performance stage 3 forced induction cam, 8.855” crank shaft lower pulley, 3.00 S/C pulley, LT4 Fueling, SMG auxiliary fuel system, 2' TSP LT headers with X-Pipe, Magnaflow Competition axleback, Mighty Mouse Wild catch can, Hurst Short Shifter. Tuned by Pray Performance. 1011WHP/982WTQ
