Old 01-24-2019, 08:05 PM   #1
Josedlc98
Drives: 6th gen camaro ss
285/35/20
will 15mm spacer help with the rubbing in the front or am i better purchasing anothee sz tire ?? thanks for help
Josedlc98 is offline   Reply With Quote
Old 01-24-2019, 08:23 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
What are the wheel specs? That will determine what size spacer you need.
Old 01-24-2019, 10:16 PM   #3
Josedlc98
20x9 30offset
Old 02-07-2019, 11:04 AM   #4
Move'n Up
Move'n Up's Avatar
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500
Originally Posted by Josedlc98 View Post
20x9 30offset
20x10 5x120 bolt pattern ET23 with a 285/30/20 tire (also 285/35-20) is the perfect setup up front.
20x11 5x120 ET43 with a 305/30/20 tire
also 305/35-20 as long as you do the harness relocate for the left rear
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
Move'n Up is offline   Reply With Quote
Old 02-07-2019, 11:40 PM   #5
Mountain
Mountain's Avatar
20x9 30offset
What’s the point of running a 285 on a 9”? Why not just run a 265? It’ll fit the wheel better, support the tire better and you dont have to worry about rubbing. Even a 275...
Also, a 285 on a 9” will be pinched and “bunch” up the overall diameter... where the 285/35 issue is.
Old 02-07-2019, 11:41 PM   #6
Mountain
Mountain's Avatar
Not all 283/35/20’s work. Sometimes you can get away with it with nearly no negative camber.
For the OP, a spacer might work. Need to knowoffset.
Old 02-08-2019, 09:08 AM   #7
Move'n Up
Move'n Up's Avatar
Do you have an specific tires that will and wont work?
