Old 01-22-2019, 09:08 PM   #1
b1gpoppa
Drives: 17' Turbocharged Camaro
Camaro problem
I drive a 17 Maro and just today driving on the turnpike/highway I felt my car moving too much to the sides. It felt pretty dangerous so I had to drive slower at around 60mph. It only happens in high speeds. The steering wheel moves to the side, but even when I hold the steering wheel the tires feel like they are moving me to the sides. Any ideas what this can be
b1gpoppa is offline   Reply With Quote
Old 01-22-2019, 09:18 PM   #2
DenverTaco07
DenverTaco07's Avatar
grooves in the highway? wide tires on concrete type highway with the grooves that run parrallel with the lane can do this.
Old 01-22-2019, 09:18 PM   #3
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Was this after a trip to the local watering hole My car often goes side to side after many tequilas....
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 01-22-2019, 09:24 PM   #4
b1gpoppa
I've been driving in the same highway for months. Just last week I felt a little bit of moving. But today it was really noticeable, I couldn't drive at 70mph+ it felt too dangerous.
Old 01-22-2019, 09:26 PM   #5
DenverTaco07
well you've come to the right place, someone here will know.
Old 01-22-2019, 09:37 PM   #6
b1gpoppa
I also forgot to mention that I hit some hard 0-60s with wheel spin last week lol
Old 01-23-2019, 10:43 AM   #7
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Check tire pressure, tire condition, and lug bolts. Then, to the dealer.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 01-23-2019, 11:19 AM   #8
ctrlz
Agree with above that tires are first thing to check.
What you are describing sounds like torque steer. In a RWD drive car that could mean rear suspension components are worn/damaged.
Can you also post more detailed description of your car? Turbo-4... but any mods, etc.?
Old 01-23-2019, 11:57 AM   #9
Silentlegion
Drives: 2019 Camaro 2SS Manual (Karnage)
Hi fairly new to the camaro here myself but for the pontiac g8 that i had the sway bar would cause this issue or the lower control arms.... just to things to look at if you haven't yet. Just check to see if they are still good solid pieces that give no play, if any of them do give play or are not sold replace or tighten down.
Silentlegion is offline   Reply With Quote
Old 01-23-2019, 12:14 PM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
It's probably just retaliating from being called a 'Maro'
Old 01-23-2019, 12:14 PM   #11
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I had that happen once when the after market trailing arm bushings failed. It was definitely scary and strange enough it only showed it's ugly head in the rain. I changed them back to the stock and the issue cleared up. That's my story and I'm sticking to it.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 01-23-2019, 12:31 PM   #12
b1gpoppa
Bone stock except for some underglow I had installed
Old 01-23-2019, 12:34 PM   #13
There are quite a few of these threads... Not sure if this is the same.
https://www.camaro6.com/forums/showthread.php?t=500793
Old 01-23-2019, 02:03 PM   #14
Turkish01
Drives: Camaro
Are you in south Florida? It’s been really windy here the last week. I’ve noticed it driving on the highway as well. I’m in a loaner Camaro right now as I’m getting the “new shudder fix” done and it’s also swaying in the wind
Turkish01 is offline   Reply With Quote
