Old 01-22-2019, 12:46 PM   #1
Randall08
Drives: 2016 Camaro RS
NEED HELP!!!!!
Anyone know where the location of the coolant temperature sensor is at on our V6?
Randall08 is offline   Reply With Quote
Old 01-28-2019, 05:11 AM   #2
Randall08
Well if anyone is wondering it is at the front of the engine underneath the intake manifold. What a spot.........��
Old 01-28-2019, 11:22 AM   #3
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Whats wrong with it ?
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 02-01-2019, 02:28 AM   #4
Randall08
My temperature gauge would stop working, fan would stay on high. It’s happened plenty of times before but I would just disconnect the negative terminal up front and it would start working again. Well this last time it happened the gauge didn’t work again and the fan would not shut off at all unless I pulled the fuse and the check engine light came on this time. Got the code read and it came up as the coolant temperature sensor. So I replaced it.
Old 06-05-2019, 05:29 PM   #5
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I appreciate you updating the thread with the location. Going to have to do that to mine soon I'm guessing as it goes off every few weeks and it's nice to find the location
Old 12-22-2021, 01:03 PM   #6
rudy.rivera77
Drives: Chevrolet Camaro
Help
Hi I just replaced my coolant temperature sensor and now it's giving me a check engine light on have check the error code. But fans are still tuning on on a cold start. Any advice on someone that has ran into same issue?
rudy.rivera77 is offline   Reply With Quote
Old 12-22-2021, 01:38 PM   #7
Andy2002a
Drives: n/a
The LT1 has a similar issue that appears to be caused by a bad thermostat. Coolant gauge goes to 0 and the fans never turn off.
Andy2002a is offline   Reply With Quote
Old 12-27-2021, 08:51 AM   #8
shadogt
shadogt's Avatar
Drives: 2016 Chevy Camaro RS V6 M6
Like Andy2002a said, when my LGX did the 0 temp displayed and fans on full blast after engine off, I replaced the sensor and the thermostat (also under the manifold).
I didn't drain coolant and it leaked all down the engine when I removed it. Not ideal, not catastrophic. Lots of cleaning up. It was a real pain to wiggle the thermostat out too.
shadogt is offline   Reply With Quote
