HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
AWE exhaust and header set up
I'm flirting with the idea of replacing my NPP with the AWE (either non or resonated) exhaust system. While I'm at it, I'm most likely going to do a header set up as well. and yet another re-tune... In the mean time, my first preference would have been the TSP 2" headers but the infamous bolt/button issue.
Anyone do a AWE combo with headers? weather it be kooks or Texas speed? I'm certain it will NOT bold right up, but if I were to keep my factory headers, the AWE would infact bold right up. thoughts are much appreciated. P.S. I now have the quickjack 7000 lift so I plan on doing it myself. if welding is involved, that may change things.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
I just got this exact set up done on mine, Texas Speed 2 inch headers into the AWE resonated Touring catback. Sounds absolutely incredible.
#3 | |
HYPER SS
- how was the installation? - assuming there was cutting involved? - did they fix the "touching" button on the steering shaft? - did you end up re-tuning? sorry for the questions, but when dropping this much coin on exhaust want to be certain.
Ordered: 1/15/2016
#4 | |
There was cutting involved and welding. Not saying it had to be welded but I had a shop do it and that is how they did it. The button on the lower part of the steering shaft just barely nicks the primary on right turns and only under certain throttle percentages. We took a dremel and ground the corners smooth on it and it seems to have fixed the issue. My car was already tuned before this so I haven't retuned but if you have an A8 it will set off the check engine light for the AFM valves and if you have NPP for those as well. |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
I have the 2in TSP headers as well and not only will the bottom bolt on the steering shaft have to be replaced but you may have to dimple one of the primaries on the drivers side because it will rub the center of the steering shaft.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
I have Kooks 2” headers and the AWE Touring catback without the resonators. My piping coming from the headers had to be extended about 1-2” to match up with the AWE exhaust.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Yup. IMO not a big deal because the drivers side is cake to take in and out. Two rounds and no rubbing and the dimples aren’t noticeable. Should ceramic coat them if they come out again
#8 | |
HYPER SS
how does it sound vs the NPP? I don't want nothing obnoxious, but a little more deeper/muscle would be good.
Ordered: 1/15/2016
#9 |
I didn't have to dent the primary because of the steering shaft but i have the new version so maybe that is why. My bottom button that sticks out was barely nicking the primary every once in a while but that was it with mine.
#10 |
HYPER SS
I would think that the head from the headers would cause the shaft to warp? eventually no? or at least degrade the strength in the shaft. being that close. I know that you now have to boot up your plug wires because of that. Unless coating your headers will help with this.
Ordered: 1/15/2016
#11 |
Yeah. It had to be cut and welded but, I don’t think it would have mattered if it was the catted or catless version. I’m confident that the piping is the same length regardless. Either way, it’s loud, really, really loud but, I think it has a great tone. I think if I had a catted version and the resonators from AWE, it would sound fantastic still. It’s something you’d have to appreciate in person.
2018 Audi TT ▊RS
#12 | |
#13 | |
![]() Drives: 2017 Camaro ZL1 Join Date: Dec 2016
Is this your car on youtube? If so, your video was the deciding factor on why I chose to go with AWE Catback, just love the way it sounds with LT headers. |
#14 |
![]() ![]() Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
can we get exhaust clips please. that be great.
Well............ At least you tried. lol
