Old 01-18-2019, 05:45 PM   #1
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
A8 Transmission Fluid Temperature?
One of the readouts on my 2SS performance display is transmission fluid temperature. I don't think I've seen this budge much above 100. What's the normal readout for routine driving in temperatures under 50 degrees?
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 01-18-2019, 06:31 PM   #2
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
Here in Florida during the summer I may see 125 degrees in my ss A8 ( during normal driving). In the winter when the temp is in the 50s and 60s I have to do some pretty aggressive driving to get the temp gauge to even register, normal driving it will stay below 100.
70chevelleSS is offline   Reply With Quote
Old 01-18-2019, 07:48 PM   #3
Silverado57
That's what I'm seeing - it has barely budged. I was a little concerned because the range goes up to 300 degrees. Thanks!
Kevin
Luceo Non Uro
Old 01-19-2019, 07:51 AM   #4
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
It won't budge hardly ever during cold weather season. I've noticed the temp will start to register when the outside temp is above like 70-80 degrees.
nancygrl is offline   Reply With Quote
Old 01-19-2019, 07:46 PM   #5
1fujifilm
Drives: 2019 Mustang GT Convertible
Even driving my new 19 Ram in WI this week pulling a snowmobile trailer I don't believe I went over 118.
Bear
1fujifilm is offline   Reply With Quote
Old 01-19-2019, 09:53 PM   #6
CoolbreezeNJ
Drives: '18 Hotwheels 2SS
Start worrying above 180 degrees but to see that and keep it there I suspect you would have to be racing. These cars have huge cooling capacity. 3 radiators up front then trans cooler is the one lying flat painted black as you peek thru the grill. Then there are oil and rear end coolers and don't forget 10 qts of oil!!!!
CoolbreezeNJ is offline   Reply With Quote
Old 01-20-2019, 01:26 PM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
GM trans fluid dexron 6 is good up to 220. Its designed for that....
Old 01-20-2019, 07:34 PM   #8
Bobkd
Drives: 2018 1ss, 2021 silverado HD
I wouldn't worry about 180 degrees. I know it's a different trans, but my silverado runs around 180 all the time when fully warmed up.
Bobkd is offline   Reply With Quote
Old 06-28-2022, 03:39 PM   #9
Red Lightening
Red Lightening's Avatar
Drives: 2016 SS Camaro Convertible
You cant even change the fluid until its a minimum of 131 F and a max of 149 f
Red Lightening is offline   Reply With Quote
Old 06-28-2022, 06:47 PM   #10
Trochoidal
Drives: 2017 Camaro 2SS A8
I’ve changed fluid twice at room temperature. Are you referring to checking the fluid level after changing it because if that’s the case, your temps are right.
