Old 01-16-2019, 09:27 PM   #1
Abi1981
Drives: Chevrolet Camaro ZL1
Brembo performance brakes on ZL1
I have a new 2018 ZL1 with barely 800 miles on it and recently the brakes started squealing when coming a stop. I keep reading that Brembo brakes on the SS have this problem and that there is no fix for it. Wanted to see if anyone had any feedback or if anyone has had the same issue and what would you recommend?
Abi1981 is offline   Reply With Quote
Old 01-16-2019, 09:33 PM   #2
fosterelli
Drives: 2019 ZL1 1LE
I've had many Brembos on previous/current vehicles. Most squeal or squeak. Some worse than others. Even with proper break-in/bedding. From my own experience it seems high performance brakes tend to make noise. You'll find a lot of Ferraris and Lambos doing the same. Some people get lucky, some drive differently, not sure...but I can't identify any way to prevent it for every HP vehicle of my own.
fosterelli is offline   Reply With Quote
Old 01-16-2019, 09:45 PM   #3
collinms
Drives: 2017 ZL1 A10 Summit White
If you brake hard a few times the noise will go away. This is typical for performance brakes.
collinms is offline   Reply With Quote
Old 01-16-2019, 10:27 PM   #4
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
This ^^
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 01-16-2019, 10:31 PM   #5
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
After a track day my brakes are quiet.
Pollock is offline   Reply With Quote
Old 01-17-2019, 07:10 AM   #6
Xeno13
Xeno13's Avatar
Drives: 2018 ZL1 1LE / Nightfall Grey
Had the same problem - cleaned the wheels with a cleaner the took off the break dust and fixex it
Xeno13 is offline   Reply With Quote
