01-15-2019, 01:42 PM | #1 |
Bannable
Battery / tender pigtail connection
I was hoping you guys could post up pics of how you have your tender pigtails set up. I have an optimate 4 and the eyelets on the pigtail are no where near large enough to work with the underhood posts. I will likely have to cut off the factory connections and solder on some new larger ones for it to work. Just curious to see what other people are doing. Thanks!
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
01-15-2019, 01:56 PM | #2 |
Drives: 2018 ZL-1 Join Date: Jan 2018
01-15-2019, 02:06 PM | #3 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
You don't have to put them under the battery lugs. Pop the top off the fuse block where the lug connects and there are several M6 terminals you can place the eyelet over and secure with an M6 nut. I think I used #4 location. For the Gnd I attached under one of the mounting screws for the fuse block. Sorry, no pics. Maybe someone else has some.
01-15-2019, 10:45 PM | #4 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
01-16-2019, 06:26 AM | #5 |
Bannable
Awesome. Thanks guys
01-19-2019, 08:47 AM | #6 | |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
