Old 01-13-2019, 10:04 PM   #1
davidmx787
Drives: Hyper Blue 2SS 2016
SS ENGINE SQUEAL FROM BELT, VERY BAD!
Hey guys,
Does some have an idea what is going on with my camaro? It started making this noise and its doing it more often and becoming worse! Has anyone experienced this before?
Thanks in advance!
davidmx787 is offline   Reply With Quote
Old 01-14-2019, 03:23 AM   #2
2SSAustin
Drives: 1LE 2SS Camaro
Nice supercharger
2SSAustin is offline   Reply With Quote
Old 01-14-2019, 05:20 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
That sounds more like a bearing than a belt. Take the belt off and check to see if any of the idler/tensioner pulleys are rough.
Old 01-14-2019, 01:23 PM   #4
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
I’ve had the same issue since I’ve owned the car. No dealer was willing to fix it under warranty in SD. I squirted a few drops of wd40 on the pulleys 4 months ago, and the problem has never returned.
soloknight6 is offline   Reply With Quote
Old 01-14-2019, 02:45 PM   #5
Umbriel
Drives: 2016 Camaro SS
Definitely sounds like a bearing. You can try the old spray and pray method with WD-40 on all the pulleys and see if it goes away.
Umbriel is offline   Reply With Quote
Old 01-15-2019, 06:37 PM   #6
sav03cobra
SS Copbait R.I.
Definitely sounds like an bearings in one of your pulleys for sure, the bearings are replaceable just get the number off of it and insert new bearings. Or try repacking/squirting some grease under the rubber part.
sav03cobra is offline   Reply With Quote
Old 01-16-2019, 12:14 AM   #7
davidmx787
They checked it out today and told me that harmonic balance damper is broken and needs to be replaced. Does it make sense?
Old 02-27-2021, 04:28 PM   #8
Darkfuzion
Drives: Camaro SS 1LE
Was there a resolution to this? My Camaro is making the exact same sound.
Darkfuzion is offline   Reply With Quote
