Old 01-08-2019, 02:10 PM   #1
MackSteelPrivateEye
Track Vs Sport Mode.
17 SS 6 speed here. I keep mine in sport mode 100% of the time because I find the low end response or response in general to be better in Sport than track mode. Does anyone else notice that? Track mode just has a louder exhaust tighter suspension and steering. I see no benefit in actual track mode engine response. Is this a factory retune issue if I were to pursue it?
Old 01-08-2019, 02:16 PM   #2
Gasoline_Farts
Drives: 19 SS 1LE
My 1LE has more rev hang in sport than track, lift off throttle in track and decel is instant.
Gasoline_Farts is offline   Reply With Quote
Old 01-08-2019, 02:27 PM   #3
V80Camaro
V80Camaro's Avatar
Drives: Camaro V8 Coupe Manual (EU Version)
I find throttle response in track is much stronger than in sport.
I do keep my steering in sport at all times though, i like the weighting best there.
V80Camaro is offline   Reply With Quote
Old 01-08-2019, 02:47 PM   #4
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Interesting. I notice no difference with rev. hang between the two. The throttle mapping is more progressive in track mode.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 01-08-2019, 02:47 PM   #5
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Interesting, I'll watch for the decel next time.
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 01-08-2019, 02:53 PM   #6
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
The Exhaust note is no different in Sport or Track. In both the Valves are open. If you pull the fuse, you will have a louder startup and cold idle.
Track mode has a progressive throttle tune which isn't nearly as "jerky" and has other specs active that sport mode does not.
You can easily change this in the mylink menu.
Do a custom setup with you're preferred handling, suspension and exhaust note.
I leave my 1LE in sport mode for the more aggressive throttle map for DD with all my settings in track mode and my exhaust fuse pulled.
There is a thread on this forum that tells you exactly what each mode brings to the table. The four mains and the 5 hidden.
I believe it also tells you in the owners manual.
WCKD 1LE is offline   Reply With Quote
Old 01-08-2019, 02:57 PM   #7
MackSteelPrivateEye
What does the fuse pull do exactly?
Old 01-08-2019, 03:13 PM   #8
TRZ06
TRZ06's Avatar
I do this too sometimes, but there is one variable that is tied to the Track
and PTM modes that you can't get in sport mode and that are the e-diff. settings.
There are 4 E-diff. modes and they are not accessible to change. The e-diff mode is different in the Track & PTM modes than it is in Sport mode. It is for this reason that when I am pushing the car around corners, I always use the PTM modes within Track mode even though I like the sport mode throttle mapping better.
The e-diff is optimized for stability in Sport mode, while the emphasis in Track mode and the PTM settings within track mode are optimized for cornering.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 01-08-2019, 04:18 PM   #9
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
I find the first half of track mode not as responsive as sport say like 1500-3500 not as punchy as sport...
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 01-08-2019, 04:19 PM   #10
squish72
Drives: 2016 2SS 8AT
kills the power going to the exhaust valves defaulting them to the fully open state all the time. Even in track mode the stock settings will close the valves at certain rpm levels to pass sound checks. pulling the fuse gets around that
squish72 is offline   Reply With Quote
Old 01-08-2019, 05:40 PM   #11
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My findings are the same as yours Mack Steel on my 16 6 speed SS. I did pull the fuse so the exhaust would stay open. Track mode acceleration response seems to be just a tad slower than in Sport mode. Also I have my exhaust set to track mode in the settings.
Old 01-08-2019, 09:23 PM   #12
Mighty Mouce
Drives: Camaro
So will the fuse pull actually effect performance/response in Sport and track mode. Or is it just an exhaust sound change?
Mighty Mouce is offline   Reply With Quote
Old 01-09-2019, 09:32 AM   #13
LT4Greg
LT4Greg's Avatar
It doesn’t affect the performance only the sound!
Old 01-09-2019, 09:58 AM   #14
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
Do you have the name of the thread or a link? Wouldn't mind familiarizing myself a little more. Mostly for the hidden modes
CamaroChriSS is offline   Reply With Quote
