![]() Drives: 2018 Camaro 2SS 1LE Join Date: Oct 2017
Single Turbo Kit - LT1
Is this even a thing? I have seen a few 1LE's & SS's running around with custom turbo kits, but I have not come across any tested kits with definite numbers. I know Hellion has a TT kit, I am looking for a big ole single turbo.
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
I think it has been discussed before, and from what I recall a single turbo sized appropriately for this size engine is just too big to fit anywhere under the hood, that is why the TT setup is much more favorable. Unless you are going Cleetus style and having a large single turbo stick up thru the hood, then TT is the way to go.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
#3 | |
![]() Drives: 16' Camaro 2SS Join Date: Sep 2015
The problem if you can figure out all the fitment issues is the downpipe size. Most can only fit a 3” if they want it to exit the rear of the vehicle. So you run into backpressure issues.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
Twins fit nice. Typically you choose single vs twins based on what fits.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
Sixgunsled is building a single turbo right now.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
I’ve mentioned it before but, I don’t think folks recall. There’s a company called Mirror Image Autoparts that makes a single turbo kit for our cars. They have a Facebook page where their first video you see on their page is a single turbo kit running on a 6th gen.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#8 |
![]() Drives: 2017 camaro SS 1LE Join Date: Jan 2017
There are a lot of companies out there that will build you a custom single turbo setup. But I haven't seen an actual all together kit from anyone except Mirror Image Autoparts as mentioned in the post above. The twin kits are just so damn expensive I decided to do a custom single kit. And I have a 88/96mm turbo so needless to say its going to be quite a task finding room to fit it and still have clearance for any sort of down pipe to the exhaust. I am going to try it and if all else fails I'll run a fender exit, but I am trying NOT to have to do that. I wen't an extra step as well by buying BMR solid motor mounts because they provide a ton more clearance over the stock motor mounts. I just finished building the motor and got it back in the car last weekend. I'll be taking it to the fab shop this week to have some custom turbo manifolds and crossover pipe made. I have a thread on here if you want to follow the progress or checkout my youtube channel Sixgun Sled and I am filming the builds I'm doing.
2017 1000+hp Camaro SS
88/96 single turbo manual to TH400 swap 15" conversion Port injection 22K+ followers on Instagram @Sixgunsled 6.4K subscribers YouTube: Sixgunsled |
#9 |
I can’t see how a custom large single kit wouldn’t cost more than twins and require more compromises. Not much needs moved to make the twins work.
#10 |
![]() Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
Like the posts above... Mirror Image Auto has the only single turbo kit for sale. They have some awesome options. Check them out! I think they’re based out of GA.
#11 |
two turbos is usually more expensive than one especially when your doing the kit yourself. Think about it, if your doing 2 turbos you have to have 2 of everything instead of 1. Not to mention paying for 2 turbo's instead of 1.
#12 |
Normally I would agree with you but to do a decent sized single would be difficult on our cars and twins fit with minimal fuss. That extra work getting a single to fit will eat up any savings of going single.
I would like to see a pic of the mirror image single kit. Maybe it isn’t as difficult as I am thinking.
#13 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Just something to consider, GM uses left and right narrow band sensor for individual bank fine tuning.
If a single turbo system is not designed properly the computer gets very unhappy. A Twin system keeping the banks separate is a far better option on this platform. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#14 |
Except there is no data, track or dyno. It utilizes a 3” dp which will be a massive back pressure issue on a 6.2l motor.
