Old 01-01-2019, 10:06 AM   #1
dlct3
Drives: 2018 ZL1 1LE
4pt Cage, 6pt Harnesses, & Rear Seat Delete Installed w/Factory Recaro's
Thought I'd share some feedback and installation photos of this combination. Overall goal was simply to retain the factory seats and function while increasing the safety within the car for some light-duty HPDE events and a couple mile events requiring a cage & harnesses. I also wanted to use a Simpson hybrid sport Hans device.
Special thanks to Jordan Best & Rosco Scott with Garage Therapy NC for the high quality cage & custom sub strap harness bars I had them build. They took an idea & made it better. Beyond pleased with their welds, fitment, powder coating quality, care in packaging, & their customer service throughout the process. These guys are killing it!! Check them out on facebook. https://www.facebook.com/garagetherapync/ Website coming soon!
Garage Therapy NC- 4 point cage w/removable rear stays option
Garage Therapy NC -Harness Bars w/Sub Strap ...& Lap Belt insert mounts if you want to utilize them. I choose to use the factory lap belt locations.
Sparco-6 point Hans Aluminum PD Harnesses
Skid Mark Garage -Rear Seat Delete (modified & upholstered to work around the cage) You could also use the Schrader Performance kit.
H3R Performance HG250B 2.5lb Clean agent Fire Extinguisher
TEK208 Quick Release Aluminum Fire extinguisher Mount
GM seat belt extender ends while on track to prevent seat belt dash light.
Simpson- Hybrid Sport Hans
Schroth Racing B23A End Fitting Kits sr01324 (2 kits)
-The cage is built to meet the safety requirements set by major sanctioning bodies for HPDE/TT events such as SCCA/NASA.
-Net weight added to the car with all above came in at 59lbs!
Installing their Brake Duct Kit today.
https://knsbrakes.com/c/car-item/447...BNmjOynSHPLBpY
dlct3 is offline   Reply With Quote
Old 01-01-2019, 10:14 AM   #2
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Pics?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 01-01-2019, 11:18 AM   #3
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Beautiful work. I wish this all came together as one kit without having to piece together all the parts.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 01-01-2019, 11:32 AM   #4
NickyRacerBoy
Drives: 1LE
Very nice
NickyRacerBoy is offline   Reply With Quote
Old 01-01-2019, 11:35 AM   #5
Shanekennett
Shanekennett's Avatar
Drives: 2022 Rivian R1T
looks awesome!
Hunting for another ZL1 1LE
Stohr F1000 - formula car fun
2022 R1T
2015 Macan Turbo
Gone-2017 991.2 Turbo S
Gone-2018 Raptor, tuned, leveled, tires/wheels
Gone-2019 Camaro ZL1 1LE...track toy...
Gone-2010 Camaro SS, built NA monster...
Shanekennett is offline   Reply With Quote
Old 01-01-2019, 12:10 PM   #6
dlct3
Thanks. If I wasn't so particular I could have bought similar items almost all from Wine Country Racing, but I wanted the Tek208 cnc'd mount and the H3R Extinguisher. Over all though it was worth the sourcing out to get the correct harnesses, mounts, etc.
Old 01-01-2019, 12:26 PM   #7
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
because RACECAR
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
Old 01-01-2019, 12:46 PM   #8
oldsailor
Drives: 2018 ZL1 A10
Curious if you picked up any road noise with the rear seat delete?
oldsailor is offline   Reply With Quote
Old 01-01-2019, 02:19 PM   #9
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Did you happen to take any pics of the (front) bar mount? I'm curious to see their chosen location for the mount. Do they include backing plates for the mounts?
seanblurr is offline   Reply With Quote
Old 01-01-2019, 04:18 PM   #10
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
Brilliant idea for the sub straps! That's thinking outside the box. I'd buy a pair in a heartbeat. Using 4-point currently because I kept the Recaros.
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 01-01-2019, 05:32 PM   #11
~Jb
~Jb's Avatar
Drives: 2018 ZLE
any cutting or drilling?
2018 ZL1 1LE (CARBON/PDR/NAV)
~Jb is offline   Reply With Quote
Old 01-01-2019, 05:56 PM   #12
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Looks great. How do the lap belts mount?
Old 01-01-2019, 06:25 PM   #13
mspeed1LE
mspeed1LE's Avatar
If it's the same as my setup, I just used slightly longer bolts to anchor the factory and race belts side by side. I had to trim a bit of the plastic trim that covers the anchor bolt(s) to make it work tho.
2005 NISSAN TITAN
Old 01-01-2019, 06:37 PM   #14
dlct3
Yes, all backing plates included and grade 8 hardware as well. The plates go through about 3 layers of of body steel at what they feel
Was the best structural points without welding in a custom cage. There’s no cutting of any interior parts or trunk lining (however, I choose to trim a few pieces so that the rear seat delete panel would lay flat around the rear stay mount locations. Nothing under the car is effected other than about 12 holes that. Hold be body plugged at removal. The pieces I cut would never be seen regardless once seats reinstalled and not visibalr from the trunk either. FYI, The cage can be removed in approx an hour if wanted.
