Old 12-28-2018, 07:00 PM   #1
parish8
Drives: 17 SS a8
who is going to run 8's next year?
cause I am! those of you running 8's all ready what is your new goal and what are you doing to improve your all ready great et?
for me #1 is to get to a 1/4 mile track more often and work through any issues. I am spending the winter on smaller refinements which should make the car more consistent and easier to dial in.
my winter list
drop about 140 more lbs, 36xx race weight with driver
better boost control, full range speed based dome boost control
line lock for more consistent burn outs
megasquirt controlled timing so timing stays where I command it
2 step
valve spring shims so I can spin it to a proper rpm
alignment, never got one done after adding bmr stuff
moon boost
Old 12-28-2018, 09:35 PM   #2
ShizzySupra
Drives: 16' Camaro 2SS
LME 416
LME Heads
New More Aggressive cam
Lt4 +30% injectors
RotoFab Big Gulp
15” Conversion
Full weight 2SS.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 12-28-2018, 09:40 PM   #3
parish8
Drives: 17 SS a8
Originally Posted by ShizzySupra View Post
LME 416
LME Heads
Lt4 +30% injectors
RotoFab Big Gulp
Full weight 2SS.
what else is done to your fuel system? meth? big bore pump and fuel pump lobe? on race gas?
Old 12-28-2018, 09:42 PM   #4
ShizzySupra
Red Ignite Ethanol, LT4 pump, DSX Aux, Meth. Was informed not to run the big bore pump as its had some issues.
Old 12-29-2018, 06:25 AM   #5
laynlo15
Drives: 2022 Lt1 A10
I want to but, just not going to make it next year. I'm pretty sure Jon will make it and be the first 2300 in the 8's
Old 12-29-2018, 08:46 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
LME 416
LME Heads
Lt4 +30% injectors
RotoFab Big Gulp
15” Conversion
Full weight 2SS.
full weight is going to make it tougher but I think you might still get there.
what issues with the lpe pump?
Old 12-29-2018, 09:17 AM   #7
parish8
Drives: 17 SS a8
I don’t know of any issues but the first large bore pumps were not compatible with a +32% fuel pump lobe. I am pretty sure the newer pumps can not only handle the 32% lobe but will go even bigger.
Old 12-29-2018, 09:32 AM   #8
ShizzySupra
After chatting with several shops we were informed it wasn’t worth the investment. I will leave it at that.
My new cam will have a +38% fuel lobe as well. Current one had +32%
Old 12-29-2018, 09:37 AM   #9
KingLT1
KingLT1's Avatar
Why leave it at that and not share what you were informed so others could potentially benefit from the information?
Same here... I knew the gen 1 style pumps could only handle a 6.5mm lobe(Stock LT4 cam is 5.99) and the gen 2 can handle a 7.85mm or perhaps even larger lobe. Be curious to know what 7.85mm equates to in percentage.
Old 12-29-2018, 10:30 AM   #10
ShizzySupra
I wasnt the one hearing it first hand. Shop called some other people after I commented that I might want to add that component. We were told it wasnt worth the money (being nice). If I get some more concrete details I will let everyone know.
Old 12-29-2018, 10:34 AM   #11
parish8
Drives: 17 SS a8
I ran the gen 1 pump for a year with no issues. the cost vs benefit is for each person to calculate and all this stuff is pricy. it sounds like someone had more of an issue with one than the cost. I am also curious.
Old 12-29-2018, 10:58 AM   #12
ShizzySupra
Think it had more to do with actual fuel volume increase.
We will see.
Old 12-29-2018, 11:19 AM   #13
laynlo15
I think I might know who you are talking about Shizzy.
Old 12-29-2018, 11:23 AM   #14
KingLT1
KingLT1's Avatar
Thanks! I know one shop was able to net another 60whp over the LT4 on a stock fuel lobe. So perhaps it's advantages only show when not using a bigger fuel lobe cam being the LT4 can potentially handle a bigger fuel lobe which negates any advantages the LPE pump had? It's really hard to judge when LPE rates the gen 2 compatible with 7.85mm fuel lobe and the rest of the industry rates the fuel lobe in percentage.
