![]() Drives: 2018 Camaro 1LE Join Date: Dec 2018
Nitrous and the LT1
School me on a good, reliable, won’t blow my car up nitrous set up for my car.
I have a GPI SS4 cam... I can get the specs when I get home, heads, e85, longtubes headers, intake. I will be getting an intake manifold soon. The car currently puts down 533hp/472tq I’m wanting to do a small 50-100 shot of nitrous. Should I do it? |
![]() Drives: 6th gen camaro ss Join Date: Oct 2018
DO IT
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Did you have to flycut the pistons to fit that cam?
100 shot of Nitrous is nothing. Do it
#5 | |
![]() Drives: Black Join Date: Jan 2017
Instead of upgrading your pistons, you could always just do it and wait until you lose a piston and then use it as an excuse to build the motor. It’s actually a somewhat logical plan since it’s not much cheaper to do it before hand. But you should be prepared for it you add nitrous in my opinion. |
#7 |
No it isn't.
#8 |
![]() Drives: Camaro Join Date: Sep 2018
I have a friend I race with at the drags, he installed a 90 dry shot on his LS2 Corvette about 5 years ago & it is his DD. It is worth about .60 tenths on his car. Last race of the season for us in great air he made a non nitrous pass of 12.21 & turned on the nitrous & went an 11.50 back to back.
#9 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
this thread is making me want to put nitrous on my car and try it out
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I will put my 2 cents in.
I started my Nitrous set up last Spring, I still have not dailed it in yet and mainly because I don’t have a warm and fuzzy feeling about my Tuners in my area. I went with the machined ring around the Holley High Rise for a even spray in each cylinder. I went with a stand alone fuel system, auto opener which I strongly recommend, auto heater blanket to turn off and on. Added safety shut off fuses for any spike. I went with all the best stuff on the market at the time and a 15 pound tank which I strongly recommend as well. Had to play with spark plugs a lot, you don’t want to melt your engine. I have done numerous 100 shots safely, a few 150, and in the spring if I get it dailed in with a good tuner I will try a 200 shot. Plan is to stay in the 100-150 area. https://youtu.be/pIfXpG51DFg https://youtu.be/rd5Zd3TThp8 ( I have since repainted Holley High Ram ) It’s a journey to get it right, still on my journey.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#11 |
BILLYSPEED
Drives: 2016 black camaro SS Join Date: May 2009
nitrous outlet set up
I have a BRAND NEW NEVER INSTALLED KIT for that car which is a bolt on kit for a diy guy or a shop . (selling my car). paid about $1400.00 with options. it has all you need. I was doing a basic 100 shot. but it goes up to 400 hp
let me no if your interested??? looking to sell at a good fair price for both of us. google nitrous outlet set up this is some quick info from there sight. "Fits all 2016-2018 Camaro SS V8 models 2016+ Camaro LT1 Specific. This system is designed specifically for the LT1 V8 2016+ Camaro SS using the stock intake manifold. A custom solenoid bracket and prefabricated hard-lines bolt directly between the throttle body and intake manifold. Complete System. This system includes all of the necessary components billet aluminum nitrous plate, 50-100-150-200 HP jetting, hardware and wiring for installation. Machined Billet Nitrous Plate. The included nitrous plate is capable of flowing 400+ HP and has a high quality anodized finish with laser engraved labels and Nitrous Outlet logo. Optional Accessories: •NItrous Oulet Bottle Heater - Warms bottle to keep at optimal pressure •Nitrous Outlet 6AN Purge Kit - Standard size purge kit•Nitrous Outlet Dual Vent Purge Kit (Windshield Exit) - (Hood Exit)•Nitrous Oulet WinMax Dual Channel Window Switch - Activate your nitrous on specified RPM, TPS, And Gear Selections new pressure guage
2010 camaro ss sold
2011 camaro 2ss/rs convertable sold 2015 ZL1 sold 2016 camaro SS sold |
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Another thing to consider for better reliability is a way to retard the ignition timing when the nitrous is active. Lingenfelter sells a box for this purpose. |
#13 |
Stand alone fuel system would be ideal. Of course there are things that need to be addressed to run a shot safely. The old standard was to pull 2 degrees timing per 50hp, 1 heat range colder for a 100, 2 for a 150, 3 for 200+ and non projected tip. Window switch is a good idea as well. In 2018 Nitrous can be a very safe way to add power with all the controllers out there on the market. The LT1 should handle Nitrous better then boost simply because you are not dealing with the same fuel system limitations as Forced Induction...not to mention High Compression and Nitrous work well together.
#14 |
Thanks for everyone input!
It’s just an idea I’ve been thinking about. It will probably be late 2019 before I get around to anything. I’m just trying to find out if it’s something I should pursue or not. I would be using everything possible to make this a safe setup. Nitrous has always scared me but here lately I see many more people using it, I’m just trying to figure out the reliability of it long term and what measures to be taken to make it safe! Thanks again! |
