Old 12-27-2018, 12:14 PM   #1
Hyper2ss2016
Drives: 2016
FS: 2016 2SS 8spd Mag Ride 550whp 4,900 mi
2016 Hyper Blue 2SS 1 owner never smoked in or ate in.
Factory Options:
8spd Magnetic Ride Contral Variable Exhaust GM ground effects package. GM Fuel door black. Ash Gray interior, GM smoked rear taillights. Navigation with larger MYlink screen. Black Premium Rims
Transferable Seat/door ding 3 years remaining Warranty.
Just about to hit 4900 miles on the odo.
Aftermarket Options
PSC-1 Stage 2 Pro Charger with Helica Gears and larger Heat exchanger. 550whp 5th gear pull 3,800DA dyno and engine/Trans then street tuned by Excessive Autosports. Specializes in Corvette LT1 and LS3 motors.
20% 3m tint.
Rear plate only currently no holes were drilled in front so would look great if your state requires a front plate to add on stow and go plate as seen on Lethal garage.
4 LED SIDE markers Orcale
$36,000 Firm. AS IS with Stock Black rims and stock tires. If it sales it sales.
Serious Inquires only. *if you want rims pictured Stance's flow forged 19x9.5 and 19.10.5 Wrapped in NITTO GS2 275 fronts and 305 NTO5R about 250 miles on them be extra 1k paid 3k in July. (37k which then also includes the stock 20inch black rims wrapped in run flats)
This car has had 0 issues with shudder etc.. She is mint accept a small scratch on the front ground effects lip which touch up paint would clear right up.
Rims and Tires will be included at 37k if you don't like the stock rims with 4,700 miles on them are pictures below.
Rims and tires that are included for the 36k
Hyper2ss2016 is offline   Reply With Quote
