Old 12-17-2018, 11:54 AM   #1
kaiserusmc13
Drives: 2018 camaro ss 1le
Mishimoto Oil Catch Can
Does anyone know if this voids warranty if installing on car and is it really worth the money?
kaiserusmc13 is offline   Reply With Quote
Old 12-17-2018, 12:49 PM   #2
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
You shouldn't have any warranty issues from a catch can. On a DI engine I'd say a catch can is 100% worth it. I've walnut blasted some some intake valves on DI engines with ~45K miles on them and it was insane how much carbon deposits there were.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 12-17-2018, 01:14 PM   #3
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Don't know about that brand, but I would run a catch can for sure.
'18 1SS 1LE Black, PDR
Old 12-17-2018, 01:24 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
If you are worried about warranty - don't do it.
You likely can't afford to prove the catch can is not cause of said engine failure or "noise" or < insert reason > for visiting dealer for warranty issue.
ing for grip.
http://www.motorsportsne.com/
Old 12-17-2018, 03:07 PM   #5
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
I would run a catch can. I have an Elite Engineering version installed.
Recently I went in to the dealership for my last free oil change. As a precaution I took the catch can off before I went in (takes about 30 minutes). When I handed the keys over to the service manager, part of the paper work was to sign an agreement/understanding that any "non-GM part" on the car could be cause for denying the warranty.
I'd use a catch can, but take it off before going to the dealer.
Mister Will is offline   Reply With Quote
Old 12-17-2018, 04:04 PM   #6
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
*SOLD*
camaroJD is offline   Reply With Quote
Old 12-17-2018, 04:41 PM   #7
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Catch cans take less than 10min if you absolutely needed to pull for warranty work.
Also yes they work, yes run one & ignore the haters
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 12-17-2018, 05:39 PM   #8
Boost Creep
Drives: '18 1SS 1LE
I have an Elite Engineering catch can I repurposed from my C6. I did a Roadkill install with zip ties near the radiator/air box since the bracket for the C6 wouldn't fit the 1LE. Heck the bracket didn't fit on the C6, so I did the same with that car except the can was by the battery. Probably take less than 10 minutes to remove should I have to go to the dealer.
I felt bad about not installing the can until 2,300 miles due to my laziness, and the 1LE being too much fun to drive and rack up miles.
It's been on for 7,000 miles and probably caught 3-4 oz of oil.
Old 12-18-2018, 01:51 AM   #9
spike2019
Drives: 2019 SS 1LE
Hi; camaro jd . I have a 2019 2ss 1le with a strut bar. Do you know what model the can is..If it is model== mmbc - cam8 -16 bpe I would be interested .. You can e-mail me at mikjan48@gmail.com Thanks
spike2019 is offline   Reply With Quote
Old 12-18-2018, 08:40 AM   #10
camaroJD
I emailed you.
Old 12-19-2018, 09:06 PM   #11
kaiserusmc13
ok I will be getting one in the future after all these holiday expenses!!!!grr
Old 12-19-2018, 10:01 PM   #12
Trackpack
Trackpack's Avatar
Drives: 1LE
No warranty issues or questions at my GM dealer with the Mishimoto catch can when the vehicle came come in for a cam and exhaust valve replacement under the bumper to bumper warranty.
Trackpack is offline   Reply With Quote
Old 12-20-2018, 09:05 AM   #13
jpdaugherty
jpdaugherty's Avatar
Drives: 2017 Camaro SS 1LE
If you can get your hands on it, Valvoline's EasyGDI & First Defense Kit is the best in the business. Carbon deposits on newer DI engines is alarming. I did a demo on my company car (2017 Impala V6) when it had ~20k miles, it was filthy. Scoped before & after, looked great!
2017 Camaro SS 1LE
IG: pdaugherty7
YouTube.com/PatrickDaugherty
jpdaugherty is offline   Reply With Quote
Old 12-20-2018, 09:40 AM   #14
94boosted
94boosted's Avatar
Seems like a neat product, but I think it's for sale for professional use only. I'm going to try the CRC GDI Intake Cleaner and pair that with a decent concentrated fuel system cleaner every 20K miles or so.
2017 - SS 1LE
