Old 12-16-2018, 01:08 PM   #1
tom's2005gto
Drives: 2016 2SS A8 Convertible
LT1 to LT4 pump lash cap needed?
Upgrading to LT4 pump and injectors. Keeping stock cam for now. Does the lash cap need to be changed for the LT4 pump with stock cam?
tom's2005gto is offline   Reply With Quote
Old 12-16-2018, 02:33 PM   #2
oldman
Drives: SS 6 speed of course
nope, you need a lash cap when go to a bigger cam lobe, because there is no way to make the lobe "bigger" as it has to be inserted into the block. So the grinder takes off from the low side of the fuel lobe(s). Since now the the low side of the lobe (the base circle of the fuel lobe ) is smaller you need something to take up the slack.
Old 12-16-2018, 02:36 PM   #3
tom's2005gto
Thank you sir
Old 12-16-2018, 02:42 PM   #4
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
If updating to lt4 high side pump and injectors, do you need a lash cap if the cam has been upgraded to a 38% fuel lobe?
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 12-17-2018, 08:05 PM   #5
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Yes, read what the "oldman" had to say.
Stefano is offline   Reply With Quote
Old 12-18-2018, 08:58 AM   #6
oldman
and the "need" is you need to measure and file. Tossing any lash cap in even the slim LS7 cap (I think that is OEM for the exhaust valve), has a chance to hammer the pump off the block. So you best be reading every thread on lash cap. I did not buy any special cam base lobe seating tool/measure device. It was pretty easy putting the cam on the base circle and filing the cap for the clearance. Which is zero clearance with no gasket and no spring on the pump. Add gasket and bingo .015 ish to .020. I did a write up on my install. I ended up with a .020 lash cap wishing I started with the LS7 would have save a lot of filing... I think the cam grinder cap is .060 and the LS7 was .040. Once again be warned the cap has to be filed or pump fly though hood (just kidding), but it can be hammered off the block, which ain't fun.
Old 12-18-2018, 12:49 PM   #7
Stefano
Stefano's Avatar
You can also use addition steel pump gaskets in order to get to the proper lash if needed, depending on the pump you are using.
Old 12-18-2018, 03:45 PM   #8
oldman
yep, and if memory serves me if I ran no gasket and no shield, I would need no shim at all
Old 12-18-2018, 05:07 PM   #9
Stefano
Stefano's Avatar
It also depends which lash cap you choose to use as the LS7 cap is different than the one from Comp cams.
8MM x 0.080" thickness - Comp Cams # 633-1
8MM x 0.060" thickness - GM part number: 12596509
Old 12-18-2018, 10:34 PM   #10
oldman
, mine with gasket ended up at .020 with a Texas Speed 32 percent cam. I think that is 7.5mm or 1mm more than stock or .040.
Old 12-20-2018, 01:33 PM   #11
laynlo15
Drives: 2022 Lt1 A10
Just found out that my Livernois has a 35% fuel lobe. So it sounds like the LS7 would give me enough for my LT4 HPFP to correct the issue with the stroke on the pump. So hopefully I'm reading the stuff correctly and this is the right direction I'm heading.
Old 12-20-2018, 06:25 PM   #12
Stefano
Stefano's Avatar
Measure twice, cut once
Old 12-21-2018, 05:46 AM   #13
laynlo15
So I still might have to grind or file the lash cap?
Old 07-09-2020, 06:29 PM   #14
teesee150
Drives: Camaro
How much clearance is required?
I just dropped in a Lingenfelter HPFP. I had a gap of .010" with the pump bottomed out at the top of the cam lobe with the comp cams lash cash (0.080"). Instead of grinding .010" off, I just used the GM .060" lash cap and called it good. Am I missing out on any extra fuel by not grinding the Comp Cams cap down to say 0.070"?
teesee150 is offline   Reply With Quote
