USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Get a magnetic drain plug they said...
So after much reading, I purchased a Dimple Products drain plug in September for a cool $41.60, today I changed the oil at 3K (second change new car) and found this! Not too impressed to say the least.
![]() Drives: 2LT Fifty Join Date: Jan 2017
At least you know it didn't leak.
![]() Drives: 2017 2ss, m6 Join Date: Jan 2017
I haven't paid much attention to it but I dont think my dimple magnetic drain plug looks like that. Did you buy it direct through them?
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Are you sure you got the genuine part and not a cheap knockoff?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
![]() Drives: 2024 2SS Join Date: Dec 2013
Yep that one must be a knock off
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
As previously stated that doesn’t look like a dimple plug (blue). Is the photo the stock plug? I have a magnetic Dorman on my truck. Works well
![]() Here is the stock plug and the dimple plug when I changed mine out ![]() Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#7 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
Why would you spend that much for a $10 plug from NAPA that does the same thing, including the magnet, and is coated ...... ?
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
watch this video, 0:44. you will see my dimple plug, its different than yours.
I bought mine direct from dimple.
ZL1::J-E-T-S JETS JETS JETS |
#9 | |
#10 | |
#11 |
Just to be clear, I was referring to the TR6060 fill and drain plugs, which are both non-magnetic from the factory. I wasn't aware of a magnet on the manual trans, but know it's common on the drain pan on autos, so just wanted to clarify that this was done on a manual.
#12 |
Who Needs to KNOW?
$41 for drain plug... hope it came w vaseline.. RIP
#13 | |
![]() Quote:
#14 |
Thanks for that info! I wasn't aware the TR6060 had that magnet.
