Old 12-14-2018, 11:43 AM   #1
wired1
Drives: 2014 Jeep SRT/2017 ZL1
ZL1 to ZL1 1LE wheel fittment
Sorry to bring this up again, my forum search only found this from 2017 on this subject and I'm confused as they keep referring back to fitment on a SS not standard Zl1.
https://www.camaro6.com/forums/showt...fit+zl1&page=3
Has anyone swapped out their standard ZL1 20'' wheels with the ZL1 1LE 19''x11F /19x12R wheels and tire combo and that has pics and can confirm if spacers are needed for front and rear and sizes 3mm or 5mm?
My 19'' OEM 1LE rims are in my cart at Wildhammer and I want to bolt up properly the 1st time around on my 17' ZL1 without issues.
wired1 is offline   Reply With Quote
Old 12-14-2018, 11:44 AM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Issue may be clearance w MR shocks vs DSSV. Body the same ?
ing for grip.
http://www.motorsportsne.com/
Old 12-14-2018, 11:53 AM   #3
wired1
That's what post seems to suggest but has this actually been confirmed by anyone that has a standard ZL1?
If so what size mm spacing and in front only?
Old 12-14-2018, 11:54 AM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Several people have done it. Unfortunately such people are usually slow to chime in or never do.
Old 12-14-2018, 02:21 PM   #5
Rodan
Drives: 2018 ZL1 coupe
Also in for results, as I'm interested in eventually getting 1LE size/spec for track wheels.
As noted above, that thread has a lot of info, but doesn't speak to the exact point. I agree that the MR shocks are likely going to be the issue, but I'm also curious how far out the fronts sit with the ZL1 fenders when they're spaced out to fit the MR shocks.
Rodan is offline   Reply With Quote
Old 12-14-2018, 02:29 PM   #6
RSFR
RSFR's Avatar
Drives: ZL1
ZL1 with ZL1 1LE spec wheels
19x11 +11 Front
19x12 +41 Rear
3mm spacer upfront, no spacer in rear
-2.8 degrees camber front
-1.8 degrees camber rear
Goodyear Eagle F1 Supercar 3R tires
305/30/19 - Front
325/30/19 - Rear
Multiple track days with 0 issues.
RSFR is offline   Reply With Quote
Old 12-14-2018, 03:54 PM   #7
Rodan
19x11 +11 Front
19x12 +41 Rear
305/30/19 - Front
325/30/19 - Rear
Thank you!
Which wheels? Looks FANTASTIC!
Old 12-14-2018, 03:57 PM   #8
RSFR
RSFR's Avatar
Drives: ZL1
Originally Posted by Rodan View Post
Thank you!
BC Forged RZ10 in matte bronze. Been a great wheel for me so far.
Old 12-14-2018, 04:43 PM   #9
checkeredflag
TPW 4-11
checkeredflag's Avatar
Drives: 2016 Camaro 2SS Conv. MRC M6 Npp
19x11 +11 Front
19x12 +41 Rear
305/30/19 - Front
325/30/19 - Rear
Looks like your car is lowered some, great stance!
Norm
checkeredflag is offline   Reply With Quote
Old 12-14-2018, 04:57 PM   #10
wired1
Thank you exactly what I needed, so a 3mm spacer should be safe in front. Rear clears harness then same as 1LE.
Your car does look amazing with color and wheel combo.
Old 12-14-2018, 05:23 PM   #11
RSFR
RSFR's Avatar
Drives: ZL1
Ah, good point. I relocated the harness in the left rear just to be safe.
Thanks!
Old 12-14-2018, 05:28 PM   #12
RSFR
RSFR's Avatar
Drives: ZL1
Lowered on Eibach springs.
Old 12-14-2018, 09:22 PM   #13
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Great looking car man!
1hprush is offline   Reply With Quote
Old 12-14-2018, 09:49 PM   #14
DANACO
DANACO's Avatar
Drives: 18 ZL1
Very sharp !
Those are not phone pics are they ?
DANACO is offline   Reply With Quote
