Old 12-14-2018, 12:12 PM   #1
Ventura 1LE
Drives: 2018 SS 1LE
Apex Wheel Options
Just wanted to share what wheel options they have. Just adding it to the wish list. Hopefully Santa is good too me this year or Mr. Tax Return.
Email response:
Cory Smetzler (APEX Race Parts)
Dec 12, 15:19 MST
Hi Richard,
Thank you for the email and I will lay out a few options for you below. My first question is how wide of a tire would you like to run? The most common setup used on the 1LE is the EC-7 in 19x10.5" ET22 squared which does require a small 5-8mm spacer to be used with cars that have Mag Ride. This allows them to run a 305/30-19, which has a lot of options for tires.
Another option would be the SM-10 if you're looking to stick with a staggered fitment. You can run 19x10" ET25 or 19x10.5" ET22 up front, both need a 5mm spacer, and pair it with 19x11" ET44 in the rear. This would be best suited for a 285/35-19 up front and a 305/30-19 in the rear.
I've attached a few pictures of the 19x10.5" ET22 square fitment. This guy (owns both) is running a 285/35 tire so he only needs to use a 5mm spacer on the front. I would anticipate some 305 tires needing an 8mm spacer just due to them being a little wider of course. Unfortunately we do not offer a wider wheel that does not require a spacer up front at this time. Also keep in mind all of our Camaro wheels require the use of a hub centering ring since they (the wheels) are produced with a 72.56mm center bore.
Cory Smetzler - Mustang Brand Manager
APEX Race Parts
Web | Instagram | Facebook
Want an immediate answer?
Pricing & Availability | Fitment Guides | Help Center
Attachment(s)
Ventura 1LE is offline   Reply With Quote
Old 12-14-2018, 12:46 PM   #2
Move_Over
Drives: ISO ss 1le
Can't see the photos - however there's a few of us around here that are running these wheels.
I for one, am running a 19x10.5 ET22 setup with 305/30/19 square tires. i ground part of my strut mount as with a -3 camber youll run into the strut.
If you're feeling really froggy, you can even get into an 18" setup, which allows for some good 305/35/18 or 305/680/18 take offs. I'm also running an 18x10.5 ET 22 square with a 10mm spacer up front, it doesn't poke too bad due to the amount of camber i have. Apex makes great stuff and those guys are great over there.
Move_Over is offline   Reply With Quote
Old 12-14-2018, 09:03 PM   #3
Ventura 1LE
Drives: 2018 SS 1LE
Here are the pics
Old 12-14-2018, 09:55 PM   #4
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Move_Over, I'd love to see pictures of the 305/30 on a 19x10.5. I'm wondering how the sidewall would look. I'm looking for a set of 19s and would like to be able to mount a range of tires on them from 275 to 305. A guy local to me said he'd get me a set of Federal 595RS-RR tires for $600 and I'd like to try them.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 12-14-2018, 10:09 PM   #5
Move_Over
Drives: ISO ss 1le
Here you go, probably upside down lol. Does he have the federal RSRR in a 305?
I’d be interested in a set for auto X if he does
Old 12-14-2018, 10:14 PM   #6
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
305/30 square Hankook RS4’s. Apex 19x10.5 et22
Provoste is offline   Reply With Quote
Old 12-14-2018, 10:57 PM   #7
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
That's the true square setup I want!
Old 12-14-2018, 11:00 PM   #8
carguy55
carguy55's Avatar
Fix the pics, just make them a horizontal rectangle
Old 12-14-2018, 11:08 PM   #9
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Too bad about the need for spacers. I have been trying to eye ball a set of new, lightweight 19” wheels for a while. I’ve had some bad experiences with spacers in the past.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 12-14-2018, 11:58 PM   #10
MatthewAMEL
MatthewAMEL's Avatar
100% agree. Spacers are fine for the street. No bueno on track.
Is it really that much more expensive to manufacture them as 'blanks' and let customers spec the offsets?
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 12-15-2018, 02:17 AM   #11
NickyRacerBoy
Drives: 1LE
Originally Posted by MatthewAMEL View Post
100% agree. Spacers are fine for the street. No bueno on track.?
Whys that? What is potential issue?
https://youtu.be/ORTE205M6ho
NickyRacerBoy is offline   Reply With Quote
Old 12-15-2018, 04:34 AM   #12
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Depends on what you are comfortable with for thread engagement. Typically, you prefer to have the same amount of threads as the diameter of the stud. So, with M14x1.5, you'd want between 9 and 10 full turns at applied torque.
With no spacer, I am at 9.5 to 10 turns. So, if I add, say a 3mm spacer, I've taken two full turns away.
There are plenty of people that run with 'x' mm of a spacer with stock studs. With extended studs, that's different as long as the spacers and well designed so they are lug or hub centric to keep from causing imbalance / vibration and also possible thread damage.
RUQWIKR is offline   Reply With Quote
Old 12-15-2018, 06:54 AM   #13
Move_Over
Drives: ISO ss 1le
Spacers are fine for the track with the correct thread engagement. Extended studs are so easy on this car my grandmother could have done it. Littlerly took me 10 minutes for both sides. I’ve been running spacers on track cars for years and there’s not an issue.
Old 12-15-2018, 07:01 AM   #14
Move_Over
Drives: ISO ss 1le
Yes it is, then every set of wheels that go out have to be cut in house and that requires so much more labor, especially when the wheel face profile is dependent upon the offsets needed. A 0 and a 43mm offset have two totally different profiles for brake clearance and spoke shape. That’s why “custom” offset wheels are often much more expensive. Apex has these offsets cut in manufacturing to help keep costa down.
A small (3-15mm) spacers really are not an issue with extended studs to get the correct clearance. Next time you are in the paddock, go poke around some of the real race cars, you’ll see one or two.. Now, I wouldnt recommend bolt on spacers with the lug studs built in for the track nor would i hop on eBay and snag a set of spacers and go drive them 10/10 on the track. Not all spacers are created equal
