![]() Drives: Red Camaro Join Date: Dec 2017
Anyone know how to fix this?
![]() ![]() Sent from my iPhone using Tapatalk Last edited by UTURNMOTORSPORTS; 12-18-2018 at 11:38 PM. |
It looks like that hood has a wrap on it. If so I would think the kink could be straightened and any bare metal covered with primer and then re-wrap it. If not a wrap or the intent is to remove and not replace the wrap then its going to need painting by a professional (unless you have that skill set and the equipment). I don't see any reason someone with decent body repair skills couldn't get that straight again and maybe with no (or very little) body filler.
Who Needs to KNOW?
Improperly packaged most likely. Nothing to prevent corners from contacting the box itself or anything beyond it. Few blocks of foam would have saved that.
![]() Drives: 2016 Camaro 1LT RS Turbo Join Date: Nov 2016
You cannot fix that if you try to bend that back the aluminum will crack.
#5 | |
![]() Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
But seriously, can you post a picture of the top of the hood so maybe you will get some better suggestions how to repair it? |
#6 | |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
Yes. Can't blame FedEx if it wasn't properly packaged. Fragile stickers won't protect the corners. Sent from my iPhone using Tapatalk |
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Try to heat the corner slightly... But I'd try to get a professional to do it. Risky.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
