Old 12-13-2018, 01:13 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JRE LT1 SUPER STREET BRAWLER PACKAGE 717 RWHP 620 RWTQ 93 OCTANE PUMP GAS
Just finished up another JRE LT1 Super Street Brawler package featuring.
Magnuson Heartbeat
85 mm pulley
Rotofab cai
JRE rough idle blower cam package
Kooks Lt headers ceramic coated w green cats
customer supplied cat back name unknown
LT4 low, high, and injectors.
JMS fuel pump voltage booster
Moroso catch can.
NGK 6 plugs
MSD wires
180 degree T stat.
93 octane pump fuel
JRE custom tuning via HPtuners.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-13-2018, 01:24 PM   #2
laynlo15
Drives: 2022 Lt1 A10
Great numbers on 93 octane.
Old 12-13-2018, 01:26 PM   #3
Redlinez
Shifts under load
Redlinez's Avatar
That's nasty! I need to play the lottery or figure something out. Congrats to that owner!
22 Suzuki GSX-S 1000GT blue
Old 12-13-2018, 01:52 PM   #4
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
One day....
red_johnny is offline   Reply With Quote
Old 12-13-2018, 03:50 PM   #5
Drsagacity
Drsagacity's Avatar
BAM! Another beat joins the fold!
We need to come up with some sort of cool badging or something that would work on these cars that would set them apart.
I think I have decided to pull all of the badging off my car...but if I could replace the SS or the side badges with something cool, I would love it.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 12-13-2018, 03:52 PM   #6
JANNETTYRACING
Years back I had some laser cut stainless JRE badges made but can't find the guy any more I have one set left for my ZL-1
Old 12-13-2018, 04:14 PM   #7
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Stock LT1 pistons?
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 12-13-2018, 04:47 PM   #8
Drsagacity
Drsagacity's Avatar
Originally Posted by VAZL1 View Post
Stock LT1 pistons?
I assume that was a manual running 8psi?
TBD performance
Old 12-13-2018, 09:12 PM   #9
Murph18
Drives: 2017 Camaro SS
Hopefully get mine in shop around March. Can't wait to see what this cam can do at the track.
Already installed
Maggie supercharger
Stainless Works 2" headers and full exhaust
Rotofab intake
85mm pulley
Ordered parts
Janetty supercharged rough idle cam
VR drop in pistons
Lt4 hpfp, injectors and zl1 in tank
Circle d converter
Dss driveshaft
80mm pulley
Going to stay on 93 for now.
Murph18 is offline   Reply With Quote
Old 12-13-2018, 09:43 PM   #10
oldman
Drives: SS 6 speed of course
what are u doing for the low side?
Old 12-13-2018, 10:23 PM   #11
Murph18
For now just the zl1 in tank. Based it off of one of Ted's other builds. If I need more low end I'll have to look into a boost a pump.
Old 12-13-2018, 10:26 PM   #12
Drsagacity
Drsagacity's Avatar
Already installed
Maggie supercharger
Rotofab intake
85mm pulley
Ordered parts
VR drop in pistons
Circle d converter
Dss driveshaft
80mm pulley
With the 85mm pulley and no cam, what kind of boost are you getting? The 80mm pulley will put you right at 10-11psi after the pulley.
Don’t forget to add the voltage booster for your low side.
TBD performance
Old 12-13-2018, 10:54 PM   #13
Murph18
With the 85mm pulley and no cam, what kind of boost are you getting? The 80mm pulley will put you right at 10psi after the pulley.
Not sure what boost its making now. But thanks for the advice. I'll give Ted a call. I was going off his other post where they made similar power to this on 80mm and it was just on the lt4 system. If it needs it I'll do it. It's a little late now to cheap out on anything.
Old 12-13-2018, 11:48 PM   #14
Drsagacity
Drsagacity's Avatar
It is part of his super Street Brawler package and I am pretty sure everyone running over 8psi with his cam has a voltage booster, ancillary fuel pump or alky injection. The voltage booster is the simplest setup because the issue isn’t capacity of the low side, but rather the inconsistent voltage supplied which results in differing fuel pump performance. The first bottleneck is definitely on the low side. Before the voltage booster was installed, I was hitting the limit of the low side...
TBD performance
