Old 12-13-2018, 09:06 AM   #1
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
Firestone Firehawk Indy 500's
Put my order in yesterday with Firestone.
285/30/20
305/30/20
We will see, nothing but rave reviews from the Corvette and SS community. Got a lot of the RE11 technology built in.
"The Firestone Firehawk Indy 500 uses a new, high-performance, silica-enhanced Long Link Carbon tread rubber compound molded into an aggressive-looking asymmetric tread design featuring large independent shoulder blocks designed to improve cornering and handling in dry conditions. The center circumferential groove features proprietary Pulse Groove Technology to enhance water evacuation, and combined with the new tread compound and two additional circumferential grooves, provides shorter stopping distances in the wet than its predecessor.
The tire's internal structure features a high-turnup polyester casing (2 ply in some sizes) beneath twin high-tensile steel belts and nylon reinforcement to provide responsive handling, stability and high-speed capability."
WCKD 1LE is offline   Reply With Quote
Old 12-13-2018, 09:35 AM   #2
Move_Over
Drives: ISO ss 1le
They’re a nice tire for the price, however that tire size in the rear may cause some issues at 1.3” larger than the stock tire. Could cause some issues as it’ll be spinning a lot slower than your front tire, causing issues with traction control. Let us know if you run into any issues.
Move_Over is offline   Reply With Quote
Old 12-13-2018, 09:45 AM   #3
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
Why go with a 35 sidewall in the rear?
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 12-13-2018, 10:25 AM   #4
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
I didn't mean 35, Total typo. 305/30/20
Old 12-13-2018, 10:26 AM   #5
FlashBang23
FlashBang23's Avatar
Drives: 2017 1LE
pretty sure thats the only 20" 305 option they make
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
FlashBang23 is offline   Reply With Quote
Old 12-13-2018, 10:28 AM   #6
FlashBang23
Drives: 2017 1LE
Interesting......TireRack only lists 35 profile available, disregard my prior comment lol
Old 12-13-2018, 10:33 AM   #7
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
[QUOTE=FlashBang23;10383560]Interesting......TireRack only lists 35 profile available, disregard my prior comment lol[/QUOTE
That only Tire Rack, Im going directly through Firestone as a special order.
Old 12-13-2018, 10:35 AM   #8
cbr1100xx
Drives: '14 Jetta 1.8, '19 1SS
Had them on my Mustang GT. Excellent tires. Good choice.
cbr1100xx is offline   Reply With Quote
Old 12-13-2018, 10:48 AM   #9
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
Any plans to track the car? Curious how much they give up compared to the Supercar 3's.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 12-13-2018, 11:09 AM   #10
Move_Over
Drives: ISO ss 1le
Their website(firestones) is only showing a 285/35 and a 305/35. You will more than likely run into your front spring perch mount with a 285/35/20, just Fyi. I want to see it work for you because i like the tires, but don't want to see you waste your mulah.
Old 12-13-2018, 11:19 AM   #11
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
You, have to call and special order them to get the 30 sizes and they we're discontinued.
But, the 35 has been run on our cars with zero problems, there are several write ups on them.
Old 12-13-2018, 11:19 AM   #12
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
Yes, Hints why my Supercars are burned out at 6k Hahaha!
Old 12-13-2018, 11:22 AM   #13
VinnAY
Drives: 18 1SS/1LE
I ran those on my Mustang and just the small caveat of "for the money", because the Firehawk name doesn't come with a premium price, they're an exceptional tire. As too was mentioned if you called them the Bridgestone Re003 they would be pricier.
I would put these on my 1LE with no reservations at all but if my budget allows me to I'd consider the PS4s
Old 12-13-2018, 11:25 AM   #14
Move_Over
Drives: ISO ss 1le
Gotcha, I’ll look into that.
Can you post up some info on that 35 profile tire in the wheels and tire thread? I’m curious to see how they are doing it as i simply don’t think there is the space for that under the 1LE / ZL1 spring perch. There’s only about 9mm worth of room over the stock 285/30 tire, and a 285/35 is nearly 13mm taller sidewall height.
