![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Whipple Phase 2 winter project
So my 17 SS M6 currently sits with the following mods:
620rwhp/595tq (07/2018) Whipple SC, 3.50 pulley LT4 HPFP & Injectors Roto-Fab dry CAI NEP Cat delete pipes (all 4) Borla ATAK full exhaust NPP with mid-pipe resonator (was not retuned after install) Catch can P3 Gauge The mods below I will be installing over the winter, all purchased, not yet all delivered. 18" drag pack (purchased late fall, was not able to get to the track with it) NW 103 TB LT4 Low side pump Kooks 2" LT no cats, jet hot coated Granatelli plug wires with heat sheilds Fresh set of NGK-6509 plugs DSS HD axles Gforce drive shaft PCM of NC Manual Fan Switch I might try and have it tuned with stock TB and then install the NW TB to see the difference in just the NW TB. We shall see how it all shakes out. Also trying to piece together a larger intake tube to replace the whipple supplied rubber tube, any suggestions there? I reached out to Roto-Fab to see if they have a solution. Cant wait to hit the track in the spring and hopefully not smoke the clutch!
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Which drag pack did you go with? On the P3 gauge, can you see the % ethanol for your fuel?
I am thinking about adding the P3 to my setup or changing to a different adm gauge so I can see the fuel trim.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#3 | |
Front Wheels: Race Star 92's 17x4.50 5x120BC 1.75"BS GLOSS BLACK Tires: M/T ET FRONT 27.5/4.0-17 Rear Wheels: Race Star 92's 17x10.5 5x120BC 7" BS GLOSS BLACK Tires: M/T ET STREET R BIAS 28x11.5-17
Yes it should display E percentage if it plugs into the obd2 port. Any guage should that reads PID's.
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Sounds like you will be faster come spring. Keep us updated. I got some stuff planned for my build over the winter as well. I will post up something when I get it figured out.
Awesome, Rob! let us know what you have planned! I hope to knock it out in a weekend in late January with the help of 2 others, i think its doable. A little more HP and a lot more traction.
#7 |
![]() Drives: Camaro Join Date: Sep 2018
My Whipple is on the way also a winter project, hope to run 10's on DR's everything else will be stock.
#8 | |
![]() Drives: 2016 1ss camaro Join Date: Dec 2015
Also, good luck with the build. I’ll be similar to yours as I’m a manual also but I’m impressed with your mph and et. How have your street tires done so far? |
#9 |
With DR's you should be able to get into the 10's for sure, Hope your build goes well!
#10 | |
best of luck with your build, research and take your time.
#11 |
![]() Drives: 2016 2SS nav mag ride npp a8 Join Date: Jul 2013
That is very cool on your next round of mods.. I too Have a Whipple going on by Spring time..
2016 2SS A8 mag ride npp exhaust nav sunroof Rotofab CAI Borla Atak NPP Corsa X pipe BBS CHR Extreme Contactsport
2.9 Whipple Elite catch can Rotofab Juiced Motorsports installed by STG Motorsports JMS Fuel Maxx tuned by Gregs Tuning Operation Weld Laguna 17x10 18x5 2006 mustang gt Magnuson Livernois stage 2 heads stage 2 blower cams dynatech headers 4.10's Circle D convertor 533/511bs) (9.8lbs) |
#12 |
About how many hours does it take to install?
#13 |
My friend and I did it, we are both mechanically inclined, he is also a certified mechanic, so we had the proper tools as well. We also did the LT4 HPFP and injectors at the same time. We tore down 1 weekend, about 12 hours, and then did the install the following weekend which was about 16 hours. The only issue we had really was our puller was not long enough to thread into the crank. But other than that it went pretty good. The worst part is putting the front bumper back on.
Make sure to install a LS crank seal GM part # 12585673 while the lower pulley is off.
#14 |
Heck yeah, you should be good to go then! Enjoy the build!
