Old 12-11-2018, 01:20 PM   #1
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
Correct PID for boost gauge using Torque Pro.
I am using Torque pro with an OBDLink MX device to montior some data. Does anyone know which is the correct for monitoring boost with a Magnuson. I found two PIDs, one which is vacuum/boost psi and another that is the intake manifold psi. The intake manifold seems to give me the right number. Idle load gives me 3.5 to 4.5 PSI, under load it goes up a bit and holds steady.
Anyone else mess around with this software (Torque Pro) ?
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
Epx998 is offline   Reply With Quote
Old 12-11-2018, 11:42 PM   #2
Drsagacity
Drsagacity's Avatar
I don’t know about that software, but I think boost is a calculation based on intake manifold pressure and barometric pressure. In HP Tuners, this is how we set it up. Since you are using the ODB2 readings, I would expect it to be the same.
https://youtu.be/X4CPLoiu9MY
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 12-12-2018, 08:42 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Vac/Boost is how most aftermarket analog gauges are set up to read.
