Old 12-08-2018, 11:34 AM   #1
ddanj
Drives: 2018 1LS 1LE
Redline increase?
I tried searching the forum but haven't found anything. Has anyone increased the redline with a tune? Is the LGX limited in any way from going to let's say 7500 or 8000rpm? I've read the LT1 is limited in that area because of valve float. Would the LGX be limited the same way? Does it matter if it's auto or manual? Obviously I have a 6MT(1LE).
Thanks
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard
3000 - 08/16/2017 | 4200 - 09/18/2017 shipped!
3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done
3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up!
4300 - 09/12/2017 Built! VIN available
4B00 - 09/14/2017 move to rail yard
ddanj is offline   Reply With Quote
Old 12-08-2018, 12:02 PM   #2
Joel2702zzz
Drives: My Dad's car is a '16 1SS 6MT
The V6 in the Camaro is a DOHC engine with 4 small light valves per cylinder so valve float shouldn't be an issue as long as you don't go crazy, but the engine is not designed to rev that high so the cams won't make good power that high and the internals may not be light and strong enough to rev that high and last very long.
Joel2702zzz is offline   Reply With Quote
Old 12-09-2018, 03:31 AM   #3
gringo
gringo's Avatar
Drives: Camaro V6
You can increase the redline, but it won't do you any good power-wise until you change the cams and tune to take advantage of the higher redline.
gringo is offline   Reply With Quote
Old 12-09-2018, 11:22 AM   #4
JakeF_RS
Drives: Camaro
Increasing the redline a little would probably put you closer to, or back into, the 5-6k powerband after shifts. Cams are practically a no go on the LGX anyhow.
JakeF_RS is offline   Reply With Quote
Old 12-09-2018, 09:12 PM   #5
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
I bet a high revving LGX would sound insanely good. Wonder what VVT delete would take.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 12-10-2018, 12:42 PM   #6
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; 2000 BMW 540i 6MT
This would be very good for a few extra mph in second gear on some autocross courses where you briefly hit the limiter, but a shift to 3rd isn't warranted. I had this last weekend at the exit of a slalom just before the finish line.
Roostie is offline   Reply With Quote
Old 02-11-2023, 03:13 AM   #7
BOSE ZO
BOSE ZO's Avatar
Drives: 2018 CHEVROLET Camaro LS LGX/TR3160
I've made some adjustments and raised the governor up to safe 7550...Nothing really finalized yet, but he seems to like it. I'll be getting rid of my sound tube soon.
https://www.youtube.com/shorts/ywbHz3WElwk
And this is the cluster
https://youtube.com/shorts/-FiVQ1NAkxU?feature=share
LorenZo
2018 CHEVROLET Camaro LS -The Giant Black SEALION-
LGX/TR3160 w/BOZE!!!!!
ig: rapidtransit
BOSE ZO is offline   Reply With Quote
Old 02-11-2023, 10:34 PM   #8
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
video is private
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 02-21-2023, 12:29 AM   #9
BOSE ZO
BOSE ZO's Avatar
Fixed.
LorenZo
ig: rapidtransit
