![]() ![]() Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
Fumoto oil drain valve opinions?
I bought one of these, the 107SX model, thinking the next oil change I would replace my factory oil pan bolt with it.
However when I came time to put it on, I threaded it and after messing with it for a couple minutes I decided that I didn't actually like it. Something about "the simplest solution is usually the best." I just felt like the regular old oil pan bolt is predictable, works well, so why change it? Has this happened to anyone else? |
Soon to be Millionaire
Drives: Blue 2016 Camaro Join Date: May 2016
Except you need to unscrew and screw the bolt every time, which means that eventually you may strip it.
Something like the Fumoto makes oil changes so much easier, quicker, and stress free. Open the hose and pour in the new.
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look |
Retired from Car mfrs....
i like the stahlbus valve better, had both. I have them on both cars , and both bikes.
#4 | |
![]() Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I've used these valves since the 80's on my vehicles for the simplicity it provides. And as mentioned, consistently wrenching it off and torquing it down will take a toll on the oil pan eventually...at least it did on my old '86 Toyota truck...changed the oil every 3k back then and at 150k miles I found a valve...not Fumoto though. It was a drain valve for something else that fit my oil pan and when I found out about Fumoto I never looked back. I eventually gave my truck to my brother when it had 250k miles and clean oil! It may not be for everyone, but I do like it and it does serve a very good purpose. However, with all that said, I will have to see how low it sits from the oil pan, since the Camaro is much lower than a truck!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
I use a Fumoto F107. Makes oil changes very easy- just slide the lever over, no need to unscrew/screw anything. Also when I added a little too much oil it allowed me to easily drain a little off.
Who Needs to KNOW?
Oil drains out so nicely without it that not really an issue and besides, another failure point.
Some cars placement and panels in way make it almost required, but here, easyy.
#7 |
![]() Drives: 2017 Camaro SS 2ss Nightfall Gray Join Date: Aug 2018
I just installed one also, i will let you know in 5000 miles how good it is lol. Cant see how it can be bad , i forgot which one i have its fumoto or straubus. I ordered both and dont remember which one i installed. But it looked safe to me and will def speed up my oil change
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels Roto fab Biggulp CAI Full paint correction with cquartz finest ceramic coating Whipple 2.9 ARH Long tube headers with High flow cats 1le sway bars F&R BMR Upper and lower trailing arms Hurst short throw shifter |
#8 |
I have the Stahlbus now and its far superior to the Fumoto. All in all either option is a day and night difference from having to unscrew your drain bolt every time. I wouldn't have it any other way.
