Old 12-03-2018, 08:53 PM   #1
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
MBRP Exhaust on an A8
Guys I really love the MBRP Exhaust and I really wanna know if anyone hear has installed this exhaust on the A8’s? If so what have you done to have it work.
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 12-04-2018, 08:06 AM   #2
Josedlc98
Drives: 6th gen camaro ss
What do you mean seemlessly ? It litterally bolts right on to the secondary cats !
Josedlc98 is offline   Reply With Quote
Old 12-04-2018, 03:08 PM   #3
AlphaCamaro7
It’s not about bolting on. It’s about the A8 being able to work with the MBRP Exhaust. Because Of the AFM I would need a tune just to put on axelbacks and that’s where I needed input. Because the M8 are a simple cut and bolt on with no tune. And I’m wondering if that could be the same case with the A8 as well.
Old 12-04-2018, 04:13 PM   #4
Calvear0
Drives: Currently Looking for 2019 SS
You will need to tune it if you get a CATBACK since I don't think they are compatible with AFM.
AXLEBACK doesn't require a tune since its just a bolt on.
Calvear0 is offline   Reply With Quote
Old 12-04-2018, 04:57 PM   #5
Josedlc98
if you get catback , leave the afm valves plugged in . Youll still go into v4 mode . Axelback you wont need a tune
Old 12-04-2018, 09:49 PM   #6
AlphaCamaro7
How will I leave afm plugged in if the mbrp doesn’t have an option to use the afm?
Old 12-04-2018, 11:12 PM   #7
chaospiece
Drives: 2018 SS, 2016 GT
Maybe zip tie the valves to the side?
Try taking the AFM motors off, leave them connected, and then zip tie them to the side and see if it throws a code.
I've thought about that once but decided to keep them to quiet down highway cruising and swaped out everything else.
chaospiece is offline   Reply With Quote
Old 12-10-2018, 09:47 AM   #8
CompleteStreet
CompleteStreet's Avatar
Drives: 2018 Camaro ZL1 A10
This is correct.
CompleteStreet is offline   Reply With Quote
Old 12-13-2018, 01:59 PM   #9
init4fun
Drives: 2017 50th Anniversary
I have the axle back on my A8. Just bolts on with no issues and no tune required.
init4fun is offline   Reply With Quote
