![]() Drives: 1968 Camaro RS Join Date: Sep 2017
help with third brake light swap
Just swapped out the third brake light to the smoked out version today, but the adhesive on the top side was barely sticking out so it prevents the light form sitting flush? what would be the best replacement for the adhesive. not sure about what thickness id need
The brake light is also held in place by clips, not just the adhesive. Did you push it hard enough into the slot?
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
Easiest mod to do tbh but you probably had it upside down
![]() Drives: 2017 ZL1 A10 Join Date: Jul 2014
Had the same issue first time around. The adhesive that came with it was too thick and it stuck out further than stock even though it was an OEM replacement part. Put some thin double sided 3m tape on it instead and looked much better. Don't have a part # for the tape though sorry. Lowes has a good selection you can browse.
