11-29-2018, 04:48 PM | #1 |
Drives: Camaro 1LE Join Date: May 2018
Silverado leaf springs question
Guys I bought this 2011 Silverado 1500 crewcab 4wd with the tow package brand new. The truck sits at 47,000 miles. Over the years I've noticed the ride height has lowered slightly. But the biggest change has come from the rear end which seems more harsh over rough sections of roads. I did install new struts and shocks a little over a year ago with no major improvement.
So today I took and had the rear drums turned and did a quick clean and adjust to the rear brakes. I noticed that the leaf springs are not as curved as they once were. At some angles they look like they're taking the shape of a "w" kind of? I've checked both sides and see no broken springs. Both sides are pretty much identical. Does this look normal or are a set of new springs in order in the near future? Fyi when the trucks on the wheels the springs are ever so slightly more straight than in the picture. Thanks Last edited by Silveradoss573; 02-17-2019 at 08:47 PM. |
11-30-2018, 10:13 AM | #2 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
What shock did you put on? I have noticed that some aftermarket ones don't dampen as well as others, typically the cheap ones. I don't think the springs look too far out as your overload spring still isn't touching the next spring up.
11-30-2018, 10:36 AM | #3 |
Thank you for the reply. I replaced with gm oem struts and shocks so nothing different there. The front has dropped maybe a 1/8 inch but the rear about a inch or so since new. I seen people on forums with cracked and/or broken leaf springs on 2007-2013 Silverado and Sierra 1500 trucks since posting this so now I'm even more concerned but not sure if I really should be at this point.
12-15-2018, 02:55 PM | #4 |
Drives: 2015 SS Sedan M6 Join Date: Dec 2009
Springs will sag over time. I would replace them. Not hard to do
