Old 11-28-2018, 03:07 AM   #1
Ranch41
Drives: 2011 Z06 Carbon & 2018 Camaro ZL1
2018 ZL1 Front Spring Assembly
OK, so I did my research and bought some PX1 lowering springs for a 2018 ZL1 with mrc. I watched the install instructions and video, read the install reviews, which indicated E-Z, and proceeded to perform the removal and install. Well when I get to removing the retaining bolt on top of the removed spring assembly, I was in for a very unexpected surprise. Even after the install, I did research for comments and special tools but nothing. Sorry pic is upside down, modds please fix. Anyway, the nut would spin unless I used a star bit to hold it. This was also the case for the strut assembly attached to the spring assembly. I forgot I had these pass through socket wrenches on the first set so I used a deep socket held by pliers.
Ranch41 is offline   Reply With Quote
Old 11-28-2018, 07:26 AM   #2
Klayman
Klayman's Avatar
Drives: 2017 2SS A8 Black
Yep....I found the same, Need a pass through socket:
https://www.camaro6.com/forums/showthread.php?t=539251
Man is born free, and everywhere he is in chains
Klayman is offline   Reply With Quote
Old 11-28-2018, 01:05 PM   #3
Ranch41
Stupid me! I remember reading that post while doing my research but for some reason it didn’t stick with me. Maybe because I read it was an SS but I guess this affects all 2018s?
On another note the instructions say to remove the trailing arm bolt next to the shock but mine is blocked by the solid brake line. I removed the bolt near the centerline and had to disconnect a ball connection in order to release the spring. You too?
Old 11-29-2018, 11:39 AM   #4
Ranch41
So my bad. After re-reading some of my installation research, there are mentions of requiring the pass through socket wrench. It sucks getting old-er. Anyway good job forum!
Old 11-30-2018, 12:39 PM   #5
Klayman
Klayman's Avatar
I pulled the line out and used the spring tension to pop it to the side to get at the bolt, then popped it back in the hole when done.
I thought it would be simpler/easier(based on the videos I saw)....otherwise I would have taken pics and documented what i did.....
Not saying it was hard, just some extras I was not ready for.....
Old 12-05-2018, 08:19 AM   #6
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Use a air impact wrench and there will be no need to hold anything
ICTsccaCamaro is offline   Reply With Quote
Old 12-07-2018, 07:18 AM   #7
Klayman
Klayman's Avatar
Some of us use just regular hand tools and don't have access to air tools or a compressor that can handle them.
(I need an impact wrench so rarely, I haven't been able to justify buying one.....not even an electric one.)
