Old 11-27-2018, 08:37 PM   #1
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
Stupid question
Are the primary cats on a SS the same as on a zl1? Wondering how much hp they can handle.
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 11-27-2018, 09:27 PM   #2
squish72
Drives: 2016 2SS 8AT
My father has a zl1 and we looked up part numbers. I don't know what the difference is but they use two different part numbers between the SS and zl1
squish72 is offline   Reply With Quote
Old 11-27-2018, 11:03 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I believe the diameter of the pipes are slightly different. The ZL1 is a little larger.
Old 11-28-2018, 06:48 PM   #4
Camarentino
Just trying to see how much power they can take. I was looking to supercharge and really don't want to do headers
Old 11-28-2018, 06:55 PM   #5
647
Drives: 2017 Camaro 1SS M6 Whipple SC
I have run a stock SS exhaust for about 15,000 mile with a whipple supercharger at 570whp without any issues, but the exhaust is the bottleneck.
647 is offline   Reply With Quote
Old 11-28-2018, 06:57 PM   #6
Camarentino
Thank you that is good to know
Old 11-28-2018, 07:00 PM   #7
Jfmoore79
Jfmoore79's Avatar
Drives: 2016 Garnet Red 2SS A8
I will soon be installing a P1X and keeping the stock manifolds but will use JRE off road mid pipes that remove the cats. I think most have found that this gets you close to the performance of headers without actually having them and is a decent compromise.
Jfmoore79 is offline   Reply With Quote
Old 11-28-2018, 07:04 PM   #8
oldman
Drives: SS 6 speed of course
https://www.phastekperformance.com/A...3010-11096.htm
since this bolts up to both SS and ZL1 cats, and we know that aftermarket shorty headers bolt to the other side of the primary cats, there can't be very much difference between the ZL1 and SS cat, as least in terms of tube size and dimensions. The factory header is like 2" or smaller at the collector... FYI.
Old 11-28-2018, 08:01 PM   #9
squish72
I'm sure there is Less of the blockage in the zl1
Old 11-28-2018, 09:40 PM   #10
oldman
I'm not...
Old 11-28-2018, 10:23 PM   #11
Deputy Dog
Drives: 2017 Super Sport Cam.
LOL....Thats a stupid Question!
Deputy Dog is offline   Reply With Quote
Old 11-28-2018, 10:28 PM   #12
Camarentino
I guess I want the best of both worlds. I want more power but want to change as little as possible and keep some form of cat. Even swapping out stock cats to high performance ones is a very pricey thing to do. That is not going with ceramic cats I know they're cheaper then metal ones. Plus welding I figure just about as much as a full header would cost. Gotta pay to play I guess
Old 11-28-2018, 11:14 PM   #13
squish72
I'm not...
Then why run two part numbers? If they are identical in every way?
Old 11-29-2018, 05:48 PM   #14
oldman
Maybe one has a better heat tolerance and is a tad MORE restrictive. There is say 5 hp with a cat delete, how much is there between two stock cats?
