Old 11-27-2018, 02:45 PM   #1
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
8L90 Fill tool/Adapter
Anyone know where I can buy the adapter to add fluid to the trans through the fluid level check plug on the bottom?
It is a total PITA to fill through the fluid fill hole on the side.
70chevelleSS is offline   Reply With Quote
Old 12-02-2018, 10:40 PM   #2
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
I made my own for my car; i had to weld a goofy size bolt and fitting together
you can just buy it:
Kent Moore Dt-51190
hitmix300 is offline   Reply With Quote
Old 12-03-2018, 11:03 AM   #3
70chevelleSS
Kent Moore Dt-51190
just out of curiosity, did you drill a hole through the bolt?
I have considered going to the local hardware and seeing if i could find a bolt with the same thread pattern, and using a drill press to drill a hole through the center. I could then tack weld a fitting to the bolt head and use it.
Just brainstorming.
I will probably end up just buying the tool... I hate to spend $50 on an item that probably costs $0.10 to make.
