Old 11-26-2018, 04:19 PM   #1
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Aftermarket NPP Dual Exhaust, Fuse Pull, and Possible Exhaust Valve Removal
2018 2SS with Flowmaster American thunder 817746 and K&N Blackhawk cold air intake.
Recently, my Flowmaster exhaust valves began to squeak when opening and closing. So, I pulled the fuse and solved the problem for now.
Has anyone else pulled the fuse on their aftermarket dual mode npp exhaust system? If so, any problems?
My other question is now with the fuse pulled, has anyone's exhaust valves loosened to the point of hearing a rattle? I'm wondering how easy it would be to just remove the exhaust valves on each side? It just seems like a big chore to return the entire exhaust system and replace it with a new one. Odds favor the same thing will happen again down the road.
Just looking for options if I develop a rattle with the valves always open.
njweatherman is offline   Reply With Quote
Old 11-29-2018, 10:53 AM   #2
18ss376
Drives: Camaro
So what fuse did you pull for the NPP valves?
Also did it give you a CEL?
18ss376 is offline   Reply With Quote
Old 11-29-2018, 11:07 AM   #3
njweatherman
Fuse 51. I followed a combination of a you-tube video and my manual. Worked great. I verified it by switching the engine driving configuration to stealth, tour, etc., and nothing happened. No more squeaks and rattle, and most importantly, no CEL. Let me know if you need the video; I will give you the link.
I'm still wondering what to do if the valve begins to rattle in the fully open position. It's not worth taking the whole exhaust off, sending it back to them for confirmation, and then getting a new one.
Old 11-29-2018, 11:34 AM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
nope i have afe power headers and exhaust and its plenty loud for me
Old 11-29-2018, 01:33 PM   #5
18ss376
Drives: Camaro
Can you completely remove the NPP valves with aftermarket exhaust, remove the fuse & still not get a CEL without a tune?
Old 11-29-2018, 01:44 PM   #6
kropscamaro16
i dont think so thats why i have the afe power one since it works with npp but i did have a check engine light before my tune but that was because of the headers
Old 11-29-2018, 02:44 PM   #7
njweatherman
I believe you can without getting a CEL.
Check out the thread: Flowmaster super 10's, removed the NPP.
Just don't remove the AFM valves or the AFM valve fuse. That triggers a CEL.
What type of exhaust system do you currently have on your car?
Old 11-29-2018, 11:04 PM   #8
Gasoline_Farts
Drives: 19 SS 1LE
Yes for NPP (fuse 51), no for AFM. Only Autos have the AFM valves.
Gasoline_Farts is offline   Reply With Quote
