Old 11-24-2018, 11:22 AM   #1
Jfmoore79
Jfmoore79's Avatar
Drives: 2016 Garnet Red 2SS A8
Pulled the trigger...finally!
I finally pulled the trigger on a P1X set up from JRE today and couldn’t be happier with my experience. Spoke to Al this morning and he was incredibly nice and helpful in answering my questions. Ted had worked on multiple quotes for me as I continued to change my mind on which direction to go. It’s been said many times but the entire Jannetty crew goes above and beyond. Also, I want to thank EyeFixStuff for his recommendations as my set up will be very similar. Here’s what I ended up with so far:
P1X, black, 9-10 lb pulley
Stage II intercooler
LT4 Fuel system
Voltage Booster
Off road mid pipes
AEM wide band
AEM OBD II gauge
LS3 Front crank seal
JRE Tune
I’m excited for a winter install!
Jfmoore79 is offline   Reply With Quote
Old 11-24-2018, 03:45 PM   #2
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
LT4 Fuel system
Voltage Booster
Off road mid pipes
AEM wide band
AEM OBD II gauge
JRE Tune
Excellent!! Glad to have helped! Ted will get you dialed in with this setup quickly. You’re going to love it. Be sure to post the results and your experience with it.
Edit: not sure if you have a catch can or not, I use the Elite e2x but there are other options as well. If you use a setup for boosted applications it will help with the pressure on the seals.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 11-24-2018, 04:46 PM   #3
Jfmoore79
Jfmoore79's Avatar
Yes, I plan on a catch can but haven’t decided which one yet. Debating on Elite vs Mighty Mouse
Old 11-24-2018, 05:29 PM   #4
TJay74
I have a PC D1SC on my 17 SS 1LE, there really isnt a way to plumb a CC into the system easily once you put a SC on it. The PC kit uses a manifold tapped into the fitting that goes from the throttle body to the intake manifold cover.
I had to pull my Mishimoto CC and have yet to find anything that will plumb into the setup easily. I have all 4 of the ports on the manifold that PC sends used right now.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 11-24-2018, 05:37 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Congrats.
no low side pump upgrade?
Old 11-24-2018, 06:52 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
LT4 Fuel system
Voltage Booster
Off road mid pipes
AEM wide band
AEM OBD II gauge
JRE Tune
Thank you for your business I look forward to tuning this for you.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-24-2018, 07:34 PM   #7
Drsagacity
Drsagacity's Avatar
BAM! Congrats on your decision.
You are absolutely right, Ted has an awesome team that goes above and beyond...looking forward to tracking your results with another JRE Racing car on the prowl.
Next stop...time for the cam!
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 11-24-2018, 07:57 PM   #8
Jfmoore79
Jfmoore79's Avatar
Congrats.
High side, low side, LT4 injectors, and voltage booster...better safe than sorry.
Old 11-24-2018, 08:01 PM   #9
Jfmoore79
Jfmoore79's Avatar
Ted.
Thanks Ted. I am confident I will be grinning from ear to ear!
Old 11-25-2018, 06:53 AM   #10
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Congrats and welcome to the JRE Family. Ted is the man!
Dysan911 is offline   Reply With Quote
Old 11-25-2018, 04:34 PM   #11
JANNETTYRACING
Thank you all, what a great bunch of guys!
