![]() Drives: 2014 C7 Join Date: Oct 2013
Vararam Sneak Peak at new Air Intake
The base LT-1 system will use the OEM tube . We found no flow advantage in changing it ,even up to 750HP and 7,800 RPM .
It has better Thermal-dynamics as well, yielding cooler Intake temperatures inside the plenum of the intake manifold. VR tech |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
I’m going to be completely honest here.
You guys are really late to the game. This thing better not be more than $59.99 w/ free shipping and an apology letter for tardiness. Unless there’s a substantial cost benefit to switching to this, or for new buyers to completely circumvent the existing, proven cold air intakes for this platform, you guys have a hill to climb and a lot of bias to overcome. Good luck either way.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
Maybe this will help give you an idea of why we take the time we do in developing products. besides we have been working on a different Engine product for the LT-1's that will break cover very soon.
I posted this reply in another section for a customer : Primary difference is the system delivers the flow required to support a true gain in power vs tricking the ECM to alter the tune wile gaining little to zero increase in actual airflow. Some of our competition shows a very little to zero gain over factory when you tested TUNE for TUNE on the dyno and at the drag strip. The flow bench tests when flowing through the head verify this as well. We gain over 1/2-3/4 of a pound of manifold pressure wile some others tapper off down to 13.8-13.9 PSI @ 4,900RPM -6,000 RPM ! on a stock LT-1 ,that's well over 20 Rear wheel HP on a stock LT-1! The ZL-1's are simply in another world ! Comparisons to others on those have seen over 1.5lbs of pressure added "over and above" some of the competition. We have tested on stock and modified ZL-1's and the VR is a "MUST HAVE" for any ZL-1 ,especially if it's been modified. Construction materials - The materials have far better thermal-dynamic properties than Metal intakes with coatings and even the carbon Fiber intakes . Showing real world temps that are lower by 20-30 deg F inside the manifolds plenum or inside the supercharger ! Quality - Using both Injection and Rotational molding yields a precise fit and internal aerodynamic package that rivals OEM . There are a host of design features that will be shown in the coming week . Stay tuned to our facebook page and the forums for latest updates. VR tech |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Nov 2018
Your customers will be thrilled with the results !
VR tech |
#7 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
#8 |
Not to worry, there will be no feet dragging !
We have been head long on this project for months wile simultaneously running multiple R&D programs on the LT-1's and LT-4's engines for future products. We have tested every combination possible, we even modified the stock box to the point that it outperformed "EVERY" aftermarket intake on the market wile still using the stock paper filter! Our goal was to beat what we had created by a strong margin wile setting up for both LT-1 and ZL-1 vehicles. We more than reached that goal. More updates coming this week. VR tech |
#9 |
![]() Drives: 2017 Camaro ZL1 Join Date: Aug 2018
You have got my attention... subscribed.
#10 |
![]() Drives: 2016 ss camaro Join Date: Jan 2018
I think this is the intake I will run on my car. stealthy! I like it...
#11 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
More waste of money
#12 |
![]() Drives: 18 NFG 1ss M6 Join Date: Mar 2017
Dyno graphs vs stock coming soon?
#13 |
The only worth while Dyno is from perf air intake back to stock and see if it loses ho
#14 |
![]() Drives: 2017 Camaro 2SS 50th Anniversary Join Date: Sep 2017
I'm in the market for a cold air intake. Looking forward to see what yall have to offer.
