Old 11-23-2018, 11:44 AM   #1
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Weapon X Big Gulp DI fuel system.
https://weaponxmotorsports.com/colle...nt=37716010513
Anybody running this? The stage 1 system looks like what I need and priced fair.
Or is this just the LT4 fuel system?
Old 11-23-2018, 01:39 PM   #2
KingLT1
KingLT1's Avatar
Well I contacted Weapon X. Pretty much the LT4 Injectors and LT4 HPFP, with a modulator for the low side pump that only works for 2017-18 according to them. They said the 2016's have a weaker pump and recommends doing a low side auxiliary setup.
The only reason I am looking at other options is because the LPE pump is out of stock. Or else I would just do the LT4 injectors, LPE pump, and low side upgrade.
Old 11-23-2018, 07:27 PM   #3
oldman
Drives: SS 6 speed of course
Yep, Juice has not told me when they expect it in...
Old 11-24-2018, 09:45 AM   #4
KingLT1
KingLT1's Avatar
I have been checking everywhere and nobody has one. Every vendor says they drop ship directly from LPE.
Old 12-31-2018, 04:01 PM   #5
Sixgunsled
Sixgunsled's Avatar
Drives: 2017 camaro SS 1LE
I ordered their port injection set up. I already have it but I haven't installed it. I have the motor and trans out. I just finished building the motor and I am swapping to a built TH400. I am about to drop everything in the car and start on the fuel system.
2017 1000+hp Camaro SS
88/96 single turbo
manual to TH400 swap
15" conversion
Port injection
22K+ followers on Instagram @Sixgunsled
6.4K subscribers YouTube: Sixgunsled
Sixgunsled is offline   Reply With Quote
Old 12-31-2018, 11:18 PM   #6
KingLT1
KingLT1's Avatar
Nice!
Old 01-01-2019, 02:29 PM   #7
oldman
Sixgun, does your TH400 throw any engine codes? I think you went from a M6 to TH400, just wondering. Back to your normal thread....
Old 01-01-2019, 05:58 PM   #8
ShizzySupra
Drives: 16' Camaro 2SS
It isnt installed/running yet
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 01-01-2019, 07:16 PM   #9
oldman
FWIW, I just put in my DSX, second fuel pump, line kit (super simple) super high quality. My only comment is this my STOCK GM line from tank to hard line under the car had a bad kink in it. Since the DSX kit adds in a T fitting at this same location, the stock plastic line has to be pushed even further back, I straightened it out as much as I could but it will be needing a replacement. Point being with such a huge kink in it, no wonder why people are seeing all kinds of low side limits. The line from tank to hard line is plastic and heck of small and a good part of the bend is covered by a heat shield so you really can't see if it is kinked. Mine was kinked at is final bend after the heat shield / wrap and was easy to see. Grad I went with a second line....
Old 01-02-2019, 12:11 PM   #10
Sixgunsled
Sixgunsled's Avatar
Shouldn't throw any codes. Yes I am going from manual to TH400 but I bought a module that plugs into the clutch sensor and tricks the computer into thinking the stock trans is still there.
88/96 single turbo
15" conversion
Port injection
