Old 11-21-2018, 05:59 AM   #1
Randall08
Drives: 2016 Camaro RS
Transmission Fluid
Just curious. The user manual says to change the transmission fluid at 45,000 miles. Has everyone changed it at that time or are they like me with 60,000 and still the original fluid? And if you did change it did you go with GM recommended fluid or a different type?
Randall08 is offline   Reply With Quote
Old 11-21-2018, 06:00 AM   #2
Randall08
I have a manual transmission by the way
Old 11-21-2018, 06:41 AM   #3
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
I have an auto a8, but i did mine at 23k and then had the triple flush at 34k.
If you drive hard, evwn with a manual, if the reccomended is at 45k, id shoot for 35 to 40k. Changing it now would be ok and needed. Fluids are just lubricants and the loose their lube properties with time heat and wear.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 11-21-2018, 03:44 PM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Haven't hit the mileage yet to change it. Probably wont until 2020 unless i get a job that is further away between now and then.
Is it even possible to do yourself or does it require forced flushing? I forget if the auto trans has a way to fill from the top in this generation.
Old 11-24-2018, 11:48 AM   #5
Randall08
Which redline transmission fluid are people running in the v6 manual transmission?
