Old 11-19-2018, 08:47 AM   #1
18ss376
Drives: Camaro
DSX Flex Fuel Kit
Brand new never installed DSX Flex Fuel Kit for 2016+ Camaro SS
$300
https://dsxtuning.com/collections/fl...r-16-camaro-ss
18ss376 is offline   Reply With Quote
Old 12-10-2018, 11:46 PM   #2
zl1kiko2017
Drives: 2018 ZL1 Nightfall
I am interested in this DSX flex fuel kit. However, is there a base tune that you get once this is installed? is there a need to up the injectors and fuelpump? Future mods, Rotofab intake, Kooks Headers/exhaust and maybe S/C pulley upgrade. Is there a way to swap tunes between Pump and E85?
zl1kiko2017 is offline   Reply With Quote
Old 12-11-2018, 07:30 AM   #3
That_ef
Drives: 2018 Camaro SS 1ss
You can install the kit but cannot run E85 until you get the option turned on through a tune.
No need to upgrade fuel system as it will handle the e85. If you wanted, you could put in lt4 injectors and high pressure fuel pump and zl1 in-tank fuel pump.
It is more a flex fuel tune than a straight e85. The sensor will sense the fuel mixture before going to the engine and the computer will calibrate accordingly. Just fill up with whatever gas you want and go.
That_ef is offline   Reply With Quote
Old 12-11-2018, 10:02 AM   #4
zl1kiko2017
Awesome thank you!
Old 12-12-2018, 02:28 PM   #5
18ss376
Drives: Camaro
SOLD
