Old 11-17-2018, 01:23 PM   #1
oldman
Drives: SS 6 speed of course
wideband issues
Here is what I have: HpTuner and a Ballenger AFR (which is HPTuner's rec). Well there has always been a floating ground issue with my setup. Don't want to get into it here. I do like the Ballanger because it can do lamda.
so Hp says they have a new stand alone dataloger / flasher thingy that plugs into the USB and due anytime now (been about 8 months) there is going to be a way to hook up your AFR... OK.
I know if I do a ODBII AEM UEGO widband it will send data to the can-bus, but AFAIK, it is in a/f, I need to do lambda as I go from 93 to E85 all the time.
So this is what I want, I want something that I don't need my work laptop, I want something that I can program its output to the screen either boost or lambda, I want it to be able to data log so I can send to the vendor without all the hassles of a laptop and a wideband that I can't get to work with the input.. at this point don't care how much it cost.
Old 11-17-2018, 06:34 PM   #2
oldman
Just now figured it out there is a folder under channels called: "equivalency ratio", it is NOT under AF gauges / inputs etc...
Old 11-18-2018, 09:18 PM   #3
squish72
Drives: 2016 2SS 8AT
AEM will do both a/f and lambda
squish72 is offline   Reply With Quote
Old 11-19-2018, 07:13 AM   #4
6spdhyperblue
Drives: 2SS 1LE
Also equivalency ratio error might be useful too if you didn’t see it yet
