Old 11-17-2018, 10:56 AM   #1
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
ZL1 Addons rear Diffuser review
I installed the ZL1 Addons diffuser today so I thought I’d write up a quick review. The package came FedEx in a taped up triangular cardboard package. Parts were perfect condition and as advertised. Very good quality piece and fairly heavy duty, more so than I expected. It came with 2 black screws, flat washers, and nuts, no instructions.
Install was advertised as very easy and quick. The problem I ran into though was there are 4 holes in the diffuser but only 2 screws holding the OEM valence, so it was obvious that the outer 2 holes would have to be drilled (1/4” drill bit) and use the supplied screws and nuts. The center 2 holes lined up with the factory screws so reuse of the screws would be required. However, upon installing the diffuser it became clear that the OEM screws were just too short to get them started so I had to resort to my stash of longer screws in my truck. Once the center screws are in and holding the diffuser up the outer holes can be drilled. There is no mention of this on their website and no instructions came with the diffuser so be aware that drilling is necessary! Once the outer holes are drilled the black screws and nuts can be installed. I added a stainless lock washer and changed the flats to stainless.
Overall impression is positive and the install was fairly easy once I figured out the longer center screws. Having someone to help hold it up would be good but I did it alone with my knee holding one end up as I screwed in the other end.
ssmike is offline   Reply With Quote
Old 11-17-2018, 08:17 PM   #2
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Pardon my ignorance, but what does the diffuser do?
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 11-17-2018, 08:44 PM   #3
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
Helps cut the air moving under the car to improve handling at speed. Plus they look cool. LOL
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 11-17-2018, 09:34 PM   #4
HB1SS
Drives: 17 1SS
not that one
HB1SS is offline   Reply With Quote
Old 11-18-2018, 02:43 AM   #5
Stewhoppy
Drives: 2016 Camaro SS
Fugly.......
Stewhoppy is offline   Reply With Quote
Old 11-18-2018, 10:02 AM   #6
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Yeah, kinda looks like, well...an add on! Like the concept though. Looks like it hangs a little low, curbs and speedbumps could be an issue.
1hprush is offline   Reply With Quote
Old 11-18-2018, 11:50 AM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
For it to work it should have been built into a bumper and not something that just, well, adds on. I’m not digging it
Markoz28 is offline   Reply With Quote
Old 11-18-2018, 08:18 PM   #8
Drsagacity
Drsagacity's Avatar
I prefer the replacement diffusers instead of simply adding on. The only problem is the replacement diffusers only support the quad tip exhaust...
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 11-18-2018, 08:57 PM   #9
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
That's technically a rear valence. It attaches to the bumper like stock and gives the appearance of a diffuser.
A legit diffuser usually mounts completely under the car and is flat, with a rake of 10-15 degrees at the tail end. https://www.google.com/search?q=diff...I3aNX88ELuBOzM
Same with "splitters"... most people refer to front lips or air dams as a splitter. APR makes a legit splitter.
gm, and most other companies make front lips and air dams. Theyre a dime a dozen.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 11-19-2018, 11:15 AM   #10
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea not a fan sorry
Old 11-19-2018, 12:40 PM   #11
ssmike
BL1ZZRD
ssmike's Avatar
yea not a fan sorry
Don’t be sorry, I appreciate everyone’s opinions! I’m actually on the fence too after seeing it on the car. Funny thing is I may be pulling it off because it won’t work with the Solo Performance axleback I might go with!
Old 11-19-2018, 01:15 PM   #12
Chris6748h
Drives: 2017 1ss
Have it on my silver 2017. I get nothing but compliments on it.
Chris6748h is offline   Reply With Quote
Old 11-19-2018, 01:17 PM   #13
kropscamaro16
ive been looking at the acs one lately tbh
Old 11-19-2018, 03:12 PM   #14
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
The ZL1 Addons diffuser is one of the few that is designed correctly. It has 5 to 12 deg angle and strikes and mounts under the car.
If you look at diffusers on race cars they are not pretty, but they work. It creates a low pressure area under the car which generates down force.
NewCamaroOrder is offline   Reply With Quote
