![]() Drives: Chevy Blazer Join Date: Sep 2009
P10E2 code after battery tender install
So I installed an AGM compatible tender... Now I have a P10E2 code.... And the battery apparently never went over 25%, according to the charger... What did I short out? Lol. Google isn't yielding much... So my seach syntax must be FUBAR... But if anyone has a list of codes from a GM manual somewhere... It'll let me know what I have to fix, lol
![]() ![]() Sent from my SM-G930W8 using Tapatalk |
![]() Drives: '19 2SS M6. Join Date: Aug 2018
Why did you mount the whole charger under the hood?
What did you connect the leads to?
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
![]() ![]() Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
Did you run the ground to the battery, the engine block or the chassis?
Retired from Car mfrs....
I agree, write a paragraph on exactly how you connected this. Don't ever mount the actual charger underneath the hood, if something should fail, and it gets very hot , you could do some damage, you want it on the ground outside the car with the leads going under the hood, using a SAE connector on the charger leads.
![]() Drives: 2017 Hyper Blue SS Join Date: Jul 2017
what did you connect the positive and negative leads to? i dont see the red (positive) alligator clip on the positive terminal.
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Where is the positive feed connected? I don't see a negative feed connected to the bolt.
Let us know if you need some connection direction. Hey, I like the way that sounds
#7 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Hmm all I could find was BMW info related to that code. Push the blue OnStar button on your mirror and ask for a diagnostic. Ask for the code. See if you get the same.
Fwiw I've been using Battery Tender Plus https://www.amazon.com/gp/aw/d/B00068XCQU connected to the battery directly with no isssues. |
#8 |
It was apparently a low voltage code for something in the ignition system.. I must have wiggled the battery cable enough to cause a brief drop in voltage...
Positive lead is connected to the battery input wire for the fuse box... Negative lead is connected to the ground cable beside the fuse box... I used ring terminals, alligator clips will fall off driving down the road. It's mounted under the hood so the power cord can reach, lol. I don't want to hack up the power cord until I absolutely have to. It definitely charges, though... It turns over way better... And the voltmeter hasn't spent this much time at 14.5 volts in a long time, lol. I'll probably pull it out in the summer time, but winter time, it'll be fine, heat wise. Sent from my SM-G930W8 using Tapatalk |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
P10E2 isn't on the 2016 or 2017. That code doesn't show up until 2018, so I'm guessing you have a 2018...
Anyway, here is the info on the code: P10E2 = Ignition On/Start Circuit Source Bypass Relay Control Circuit Low Voltage. Control Circuit = Short to Ground — For greater than 1 s. Sounds like the code was just set due you messing with things. What's the output of the tender you have? |
#10 | |
It's 1.1 amps at max... It's a Noco G1100. Sent from my SM-G930W8 using Tapatalk |
#11 |
Thank you Al Oppenheiser!
Ignition on + low voltage = either you left the car on and walked away, or the car glitched and kept itself on, and the battery died.
I got a triple honk once when the keyless system glitched (key outside the car). Came back the next day to a dead battery and this same code. |
#12 | |
Battery cable got bumped, and likely had a momentary weak connection.... None of my settings or clock got reset, so it didn't get disconnected for any amount of time, lol Sent from my SM-G930W8 using Tapatalk |
