Old 11-16-2018, 12:35 PM   #1
MatthewAMEL
MatthewAMEL's Avatar
This ok with RotoFab?
I believe the Roto-Fab seals using the hood.
Is this ok?
Came this way out of the box.
Thanks in advance.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 11-18-2018, 12:19 PM   #2
Kaludar
Drives: 2018 SS 1LE
Probably not ideal but I doubt it makes very much of a difference. Only a tiny bit of air is going to come in through that divot.
Kaludar is offline   Reply With Quote
Old 11-18-2018, 03:27 PM   #3
laynlo15
Drives: 2022 Lt1 A10
It will probably seal up just fine. If it doesn't let Mike know and they'll probably just send you another.
Old 11-18-2018, 11:19 PM   #4
Roto-fab 1
Roto-fab 1's Avatar
You can pull up on the hood seal slightly disengaging it from the air box. That should fix the wrinkle in the rubber seal.
