Old 11-12-2018, 01:27 PM   #1
Kaludar
Drives: 2018 SS 1LE
To catch can or not?
Hi guys, had my ‘18 1LE for about 900 miles now, and I’m trying to decide if I want to go ahead and put a catch can on or not. I’ve heard both sides of the debate some people think they are pointless some that they are a necessity. How many of you run one on your 1LE? I run my cars pretty hard, this one even more so cause the sound and power is so intoxicating, is it better safe than sorry to throw one on there?
Kaludar is offline   Reply With Quote
Old 11-12-2018, 01:33 PM   #2
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
no reason NOT too,
I pull oil out of mine, its not as much as I get out of my grand Cherokee, but oil all the same that would be all over my intake..
biker2k is offline   Reply With Quote
Old 11-12-2018, 01:48 PM   #3
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Read the many threads and make your own decision.
I’d never run without one after testing for 500 miles
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 11-12-2018, 02:53 PM   #4
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Originally Posted by biker2k View Post
no reason NOT too,
Seeing the cold weather water/fuel/oil buildup in another thread made me think twice.
camaroJD is offline   Reply With Quote
Old 11-12-2018, 04:15 PM   #5
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
If you don't routinely get your oil temperature to 200 degrees (short trips) that moisture in the catch can is still there, only in your engine where you can't see it. I routinely pour an ounce or so out every few weeks, I believe its worthwhile.
Warrior102 is offline   Reply With Quote
Old 11-12-2018, 04:34 PM   #6
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Why not.
I collect about 1.5oz every oil change.
That would have just burned off and ended up in the cats, or formed carbon on the valves, pistons, or cylinder heads, none of it any good.
Oil has no business in your intake.
It's a contaminate.
'18 1SS 1LE Black, PDR
Old 11-19-2018, 12:57 AM   #7
spike2019
Drives: 2019 SS 1LE
catch can
I have a 2019 camaro 6.2 litre ss 1 le 6 speed manual with a factory strut tower brace. I want to put on a catch can does any one know where I can get one that will fit with the brace. thanks e-mail = mikjan48@gmail.com
spike2019 is offline   Reply With Quote
Old 11-19-2018, 07:13 AM   #8
18ss376
Drives: Camaro
I like mine, very cheap & easy install. Keeps oil off the top of the intake valve.
18ss376 is offline   Reply With Quote
Old 11-19-2018, 11:14 AM   #9
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
none here 25k miles bolt ons and tuned no issues
Old 11-19-2018, 12:00 PM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Some say you should, others say you don't need it. I had my intake manifold off(for porting) the engine at 3k miles and there was a little bit of oil coating the intake ports. Nothing crazy and the valves looked good. I still added a catch can and it catches a ounce or so every 1500 miles. Better then being burned out the exhaust.
KingLT1 is online now   Reply With Quote
Old 11-19-2018, 02:09 PM   #11
hotlap
hotlap's Avatar
I drive mine 17 mile each direction to work so getting up to temperature isn't a problem. My catch can filled with water in less than a week when the temps dropping below 20º. I won't put another can on a car
see more here
https://www.camaro6.com/forums/showp...24&postcount=5
Ronald Reagan -
Old 11-22-2018, 06:17 AM   #12
DorkMissile
DorkMissile's Avatar
Drives: DZ
I don't daily my SS1LE, but this is just one weekend of driving my car (bone stock other than the Elite catch can)
This could all be running strait into the intake, valves, and combustion chamber. I am glad I have a can is all that I can say
DorkMissile is offline   Reply With Quote
Old 11-22-2018, 06:34 AM   #13
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
No reason too.
Old 11-22-2018, 06:54 AM   #14
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
I use the UPR 4 stage passenger side can & it gives me "peace of mind", I get about 1-2 oz. per oil change. UPR may have an application for your Camaro's.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
