Old 11-07-2018, 01:59 PM   #1
Same 93 gas, same gas station, car feels different - is this real?
Just filled the tank up for winter, and as I drove home from the gas station, the car felt less powerful than before. Same pump and same 93 as the previous fill.
Is this all in my mind, or is there a difference between summer/winter gas and I happened to have hit some sort of cutover?
Old 11-07-2018, 02:01 PM   #2
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
Gas stations change the blend they use in the winter months.
https://www.popularmechanics.com/car...ence-13747431/
lgarrison34 is offline   Reply With Quote
Old 11-07-2018, 02:06 PM   #3
Umbriel
Drives: 2016 Camaro SS
Probably just in your mind.
Umbriel is offline   Reply With Quote
Old 11-08-2018, 05:57 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Because no gas station owner would EVER "accidentally" swap a cheaper grade into the premium tank to make an extra $2000 bucks...
Old 11-08-2018, 06:26 AM   #5
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
I agree.
Corvette_Mike is offline   Reply With Quote
Old 11-08-2018, 06:38 AM   #6
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
So the owner of the gas station forced the delivery driver to pump regular into the premium tanks?
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 11-08-2018, 07:01 AM   #7
Nsxmatt
Drives: 2017 Camaro
This. Even if they put 87 in the tanks (not likely) the car would still drive normal on the way home till the ECU pulled some timing. The most likely scenario is you just added 100lbs worth of weight in gas to your car.
Nsxmatt is offline   Reply With Quote
Old 11-08-2018, 09:36 AM   #8
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
i'd vote in your mind or unrelated to the fuel. There's enough fuel in the lines and the ecu would take additional time to register the change in octane since it would be something it responds to from the combustion (there's no octane sensor in your fuel tank) that bad fuel would not be something you'd immediately notice.
Old 11-08-2018, 09:41 AM   #9
Thanks guys for all the responses, I appreciate your help. It must have been the extra weight or just me reading too much into little things. I'll hook up the OBD dongle and check this more scientifically.
Old 11-08-2018, 09:49 AM   #10
ctrlz
I definitely can feel the difference in the car going from a near-empty tank to full. It is more noticeable in some cars than others, and this is one of them.
Old 11-08-2018, 10:39 AM   #11
TJay74
Summer to Winter blend fuels will do this as well.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 11-08-2018, 10:47 AM   #12
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
I see the OP is in NJ. NJ definitely has a winter blend of fuel.
Have I mentioned how much I hate NJ?
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 11-09-2018, 09:39 AM   #13
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Winter blend gas....In the same boat here in NC.
nancygrl is offline   Reply With Quote
Old 11-09-2018, 12:23 PM   #14
Nsxmatt
Drives: 2017 Camaro
People. OP said he felt it immediately on the drive home. Winter blend is not going to alter the ECU timing that quick especially with old fuel in the lines and fuel in the tank. It's also not going to affect you power output THAT much.
