Old 11-05-2018, 09:56 AM   #1
BTK
Drives: 2017 2ss
Tire psi question
I've seen quite a few posts in the "MRC jacking up" thread about airing up the tires to 40psi for storage. This has me questioning my operating philosophy on tire air pressure. I currently run my tires at 43psi, with the thinking that the recommended pressure of 35 or whatever is for a softer ride, but more pressure = better economy, tread wear, etc. Am I wrong? This is a lesson I learned from my father 30 years ago. "Run tires at the highest pressure you can without affecting tread wear..." Admittedly, he was always a truck guy, so there may be a difference there due to loading, towing, etc. Thoughts?
BTK is offline   Reply With Quote
Old 11-05-2018, 11:50 AM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
43 is way high. For the tires on these cars, I wouldn't recommend running much more than 1 or 2 PSI over the recommended pressure at most. Recommended pressure is not just for softer ride, it impacts how your tires interact with the road and therefore everything about the dynamics behind a moving vehicle.
Higher pressure only gets you better economy because you're reducing the size of the contact patch with the road. While this does mean less torque is needed to turn the tires, it also means you're not going to have as much grip of you need to turn suddenly or stop hard, and this will only be made worse in wet conditions.
Higher pressure also hurts tread wear. The same smaller contact patch from above is also not as good at reacting road loads as the contact patch at the correct pressure would be and in turn gets worn/damaged faster.
I'd suggest dropping back down to the recommended pressure listed on the sticker in the door frame, and if you're getting poor tire wear after that you could get an alignment. If the outsides of the tires are worn more, get the track alignment listed in the track prep performance supplement (can find that on this forum if it didn't come with your car). If the inside is wearing too much or tire wear in general is poor, try to find an alignment shop that will do the standard camber alignment while moving the toe alignment to be closer to the track alignment spec (i.e., closer to 0 total toe).
Keep in mind that this is a performance car with softer tires than most, so don't be surprised if the tires look more worn than a family sedan's tires after 20k miles. There are other all season tires with better treadwear ratings available as well if you're not keen on the lower treadwear rating of the OEM tires.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 11-05-2018, 12:00 PM   #3
VinnAY
Drives: 18 1SS/1LE
"Without affecting treadwear" would mean 32psi cold. Like the door jamb tells you too. 43psi is ridiculously high and WILL affect treadwear.
Old 11-05-2018, 12:36 PM   #4
nelsont
Drives: 2018 2SS Hot Wheels Convertible
Ya the engineers don't know a thing- why would you want the car to ride like a buck Board?
Follow Mfg. recommendations.
Tim
nelsont is offline   Reply With Quote
Old 11-05-2018, 01:10 PM   #5
BTK
Drives: 2017 2ss
Thanks for the good explanation Alpha1BC. As I said, I was going off what was taught to me 30 years ago. And yes, he was an "engineers don't know a thing" kinda guy and said that number on the door jamb was so you would have a softer ride, no other reason. I guess my father didn't actually know everything. Go figure.
Old 11-05-2018, 01:52 PM   #6
VinnAY
Drives: 18 1SS/1LE
I do remember a time though that it was on the side of the tire like it just said max PSI or something like that, trying to think that far back before there were labels on the door jambs
Old 11-05-2018, 02:27 PM   #7
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Maybe not, but your father-in-law certainly will.
No matter what I tell my wife, she doesn't believe it unless it can be corroborated by either her dad or the internet.
One thing you will never, ever, hear your wife say, "Oh honey, you're so clever. You're much smarter than my father."
Old 11-05-2018, 02:28 PM   #8
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
The ‘19’s call for 35psi as per door jamb.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 11-05-2018, 02:44 PM   #9
DangerZL1
Drives: 2023 Black ZL1 Auto
Wow! You're going to almost think you bought a Cadillac when you take 8 psi out and realize how much better it handles bumps. If 43 is a cold psi, it probably goes to 45 or more hot.
Old 11-05-2018, 06:30 PM   #10
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
43psi..
nancygrl is offline   Reply With Quote
Old 11-05-2018, 11:39 PM   #11
GroundhogSS
GroundhogSS's Avatar
Two over, maybe three at the most.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 11-06-2018, 12:53 AM   #12
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
43 cold.. what are they hot? 48? haha, crazy
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 11-06-2018, 09:15 AM   #13
TJay74
The PSI varies depending on the model, the SS 1LE cars call for 32psi cold. The tire pressure on the tires is the max tire pressure for when the tire is at its max load.
As said, no more than 3psi more than the door jamb is a good rule of thumb.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 11-06-2018, 09:35 AM   #14
BTK
Drives: 2017 2ss
Indeed! Old school thinking, performance = hard ride, luxury = soft ride!
This exactly. I've had many cars that did not have any info on the jam, weather it fell off, was painted over, or was never there... These run flats have a max of 50psi. The tires on my 2500HD have a max of 80psi, I run 65 front/60 rear.
The recovering addict in me says ANYTHING less than MAX is NOT GOOD. Obviously not true, but it does affect a lot of my decisions
Thanks for the info everyone. I'll be airing down today .
