Old 11-04-2018, 05:05 PM   #1
laynlo15
Drives: 2022 Lt1 A10
Drove my camaro and video at idle
Got everything finally finished, well kinda. When I did light the fuse it wouldn't idle because the tune wasn't installed yet but man it sounds wicked I must say. Everything turned out good, I will get to drive it sometime this week, the weather is not good here in Missouri, rained 2 inches today so maybe by Tuesday I can get it out for a spin.
https://youtu.be/9NubCUmftZo
https://youtu.be/XiHvoZBx4-o One of my last passes before new motor
Old 11-04-2018, 07:05 PM   #2
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Congrats.......still time to make a few hits : )
Stefano is offline   Reply With Quote
Old 11-04-2018, 07:55 PM   #3
laynlo15
Gateway closed this weekend, if that happens I'll have to go south of Missouri. Next week looks cold and wet. Not so good right now.
Old 11-04-2018, 11:35 PM   #4
Drsagacity
Drsagacity's Avatar
Let me know if you decide to head south, I may make the trip too.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 11-05-2018, 05:24 AM   #5
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Congrats, glad to hear it started up! I can't imagine how excited you are.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 11-05-2018, 06:34 AM   #6
laynlo15
Needs a lot of tuning, I have logged just the idle part and got a tune for that. Need to put the correct pulley to drive it tomorrow since the weather sucks here today. I'll keep you all up to date.
Old 11-05-2018, 07:49 AM   #7
ShizzySupra
Drives: 16' Camaro 2SS
Go with stock cubes? Put main studs in it?
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 11-05-2018, 08:25 AM   #8
Drsagacity
Drsagacity's Avatar
Which pulley are you going to run?
I swapped to the 80mm pulley for winter, but once you get your pulley setup, can you post which belt you are using. Inquiring minds want to know.
TBD performance
Old 11-05-2018, 11:18 AM   #9
Jhunsberger
Kind of off topic to your new engine, but what is your impression of the gains of the NW TB? I know they are most beneficial to a PD SC, was thinking of adding that to my setup.
Old 11-05-2018, 01:43 PM   #10
laynlo15
Shizzy I did stay as close to stock as I could, we had to go ten over on the bore because of the damage to number 1 and 8. I did install the Arp main studs and head bolts and the compression is down to 10.5 so we don't have to worry so much about having issues as we did with the higher compression. I'm switching to the 80mm pulley for break in and work down from there once I get some logging done. I'm also worried about the tranny having issues, didn't shift right on the last pass when it blew out the rear seal. I'm going to reflash the tranny again and see what that produces when I get a chance to drive it, maybe tomorrow depending on the weather. I think we gained 13 rwhp with the NW.
Old 11-06-2018, 04:21 PM   #11
laynlo15
So I finally go to drive my Camaro for the first time since July. Dam I missed it and everything went just fine. Gotta get that exhaust fixed.
Old 11-06-2018, 10:54 PM   #12
Drsagacity
Drsagacity's Avatar
What’s up with the exhaust? Did you keep the cats? If so, be careful you don’t burn them up and blow another engine.
TBD performance
Old 11-07-2018, 06:29 AM   #13
laynlo15
Cats are good, car drove good but need more tuning under heavy throttle, has a little stutter then just blows the tires off at 80 mph. I just have to have the cats welded to the connector pipes. Might have that done today at lunch
Old 11-08-2018, 11:56 AM   #14
ShizzySupra
Thanks for sending me the videos! Thing sounds GREAT and is going to be MEAN!
