Old 11-03-2018, 08:52 AM   #1
Deadmau5
Deadmau5's Avatar
Drives: 2015 procharged mustang gt
Cam install question
Hey guys so I'm getting cam installed by friend at dealership it's a stage 2 weapon x cam (tsp made) and it came with all necessary equipment to install pic of everything included listed below with ls7 lifters. Well he is almost done installing the cam but told me he ran Into a hiccup and that he has a 0° phaser limiter and not the lt4 4° limiter. And per some instructions he saw on tsp website it says 4° needed for lt4 but there's is 32% fuel lobe and my weapon x one is 38% . I'm almost 100% positive whatever weapon x sent is accurate and needed but want to be safe as he tried to contact them but they have been busy so unable to make contact for passed two days. Now idk why he says it's a 0° phaser limiter cause part number from picture I took show's it's the lt4 phaser limiter part number (comp cam 5451 ). Any help on would be much appreciated ! Trying to have car finished today .
Sent from my Pixel 2 XL using Tapatalk
Deadmau5 is offline   Reply With Quote
Old 11-04-2018, 06:03 PM   #2
JimW
JimW's Avatar
Drives: 2011 Camaro
mine has zero degree in it .. had to be torn down and swapped from the 4 degree cause of lost power in the upper rpm. Running btr stage 1 with a10 trans
2017 Garnet red ZL1 A10 Procharged LME 427 L8T
JimW is offline   Reply With Quote
Old 11-04-2018, 10:31 PM   #3
Deadmau5
Deadmau5's Avatar
Ok so zero like they sent me .
Old 11-05-2018, 08:13 AM   #4
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I plan to do mine this holiday what was the cost if ya don't mind me asking..
BTR cam
BTR springs, retainers, locks (seals not sure if there in kit)
BTR Pushrods
Cam Phaser kit
4 degree phaser
GM LS7 Lifter
GM LS7 lifter trays
GM LS1 crank seal
GM LS1 Crank Bolt (I Have a ATI balance)
GM Head Gaskets
GM Head Bolts or (ARP)
GM Cam Bolt
GM Silicone?
optional..
c5r chain
Bushing trunnion upgrade
upgraded exhaust valves
Old 11-05-2018, 11:53 AM   #5
oldman
Drives: SS 6 speed of course
I did not have any specs when I put the stage 1 supercharge TSP / Pray cam in. I think my limiter is 20 degrees... which is the only one I could find on the TSP site. My cam is small though. As long as the tuner knows, there should be no issues.
Same goes for the lobe, is it 32% or 36%, there is .35mm more lift (.014"). The only real problem is to make sure your lash cap is installed via measurements. Your friends dealership, better know what they are doing or read up on it. You can't just put the lash cap on and hope. If the mechanic has not ground a lash cap to fit, take it to a real shop.
Old 11-05-2018, 12:08 PM   #6
Deadmau5
Deadmau5's Avatar
So does the degree vary from build to build ? I've only heard of 4&0 degree limiters . My car has a 38% fuel lobe
Sent from my ONEPLUS A6013 using Tapatalk
Old 11-05-2018, 12:09 PM   #7
Deadmau5
Deadmau5's Avatar
BTR cam
BTR Pushrods
Cam Phaser kit
4 degree phaser
GM LS7 Lifter
GM LS7 lifter trays
GM LS1 crank seal
GM Head Gaskets
GM Cam Bolt
GM Silicone?
optional..
c5r chain
I got everything from weapon for a great price they discounted everything to like 1400 ish and change
Old 11-06-2018, 10:11 AM   #8
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
0 degrees is better from what ive heard. Apperantly there are issues with the vvt going crazy due to fluctuations in oil pressure, so most tuners like o degrees. It will be just like a regular cam if you talk to cam motion,mti, even tsp they prefer 0 degrees. Fuel lobe overdrive percent has nothing to do with vvt
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 11-06-2018, 09:55 PM   #9
Deadmau5
Deadmau5's Avatar
Nice! It's just weird cause on tsp site it says lt4 needs 4° and not the 0 and weapon x gave me a zero so I figured what they sent me was exactly what I needed.
Old 11-06-2018, 10:07 PM   #10
laynlo15
Drives: 2022 Lt1 A10
We locked mine out, no vvt. I was orginally going that route but changed since I really only drag race mine. Just drove it the first time today. Kinda nasty I'd say
