![]() Drives: '18 Camaro SS Join Date: Sep 2018
Tuning out AFM & Cat Deletes
Hey guys! To keep it short and sweet - My midpipe removes the AFM and the secondary cats. My boy has HP Tuners with credits. Can I install the midpipe and just turn off the AFM light and Check Engine Light via HP Tuners that will arise? Will I need to actually tune the car so the a/f ratio is good? Holding on to my warranty for 1 more week if this works
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
You can just turn the lights off but the car will need a tune to adjust for the new parts. It will run ok without a tune just be a little rich.
You can turn off AFM valves in the FSCM controller via HPtuners. Shouldn't need to do anything else.
SNSTRSS
Can you specify where? Have you done this? I see that HPT shows a red brickable text.
2016 Black Camaro 2SS A8 NP
#6 | ||
AFM is a simple off switch. I used to do mine like this guy did... gear by gear. |
#7 |
#8 |
SNSTRSS
My question was in reference to removing afm valves and tuning them out so no check engine light. I guess this should be in the tuning section. Turning of dod in hpt is just a click to disable but afm valves and cel is not that simple. I actually reconnected afm modules and zip tied up. All codes and cel reset and no more cel.
#9 | |
Couple tips. -Read your FSCM and save it...that way you can revert back to stock. Don't try and flash a 2015 Z28 file you found on HPtuners. -Then you can license it for 50.00 and make adjustments to the fuel and exhaust system, such as raise fuel pump voltage for the intank, adjust the open and close function of the NPP exhaust valves, and turn off/on AFM valves.
#10 | |
SNSTRSS
#11 |
![]() Drives: 2017 1ss camaro Join Date: Nov 2018
Need help finding the right part
I have a 2017 SS Camaro. I have installed a custom Cat/back exhaust system and have removed the atf exhaust valves. I would like to know how and where to purchase the connectable EFI tuners so my check engine light will go off. I would also like a recommendation on deleting the AFM system so I run on 8 cylinders only. Any help would be appreciated.
